3-Way Switch Help - Electrical - DIY Chatroom Home Improvement Forum
Old 07-02-2008, 07:09 AM   #1
Rewards Points: 109
3-Way switch Help
Hello, I have a 3-way switch that controls a light in my basement. Im replacing the wire due to it being old and falling apart. The wire has no markings so im not sure what wire is what so I drew a diagram with numbered wires and was hopeing that someone could tell me how it was wired or what number wire conects to what number wire. Here is the diagram. Thanks!
oxicottin is offline   Reply With Quote
Old 07-02-2008, 08:00 AM   #2
joed's Avatar
Rewards Points: 13,310
Connect all the green grounds together and to any ground screws on the switches.
Old 07-02-2008, 03:50 PM   #3
Rewards Points: 109
joed, I tried your wireing diagram and turned on the power and nothing I followed your very easy directions. I have a question about how they are connected to the switches. There is a black screw on the switch which is on the side with 2 terminals. In your diagram it show the black screw by itself on one side. Going by your diagram I connected one white wire to the black screw on one switch and on the other switch I connected a red. Is this correct? Thanks!
Old 07-02-2008, 04:41 PM   #4
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
In your junction box put 11 & 15 together then 15 goes on the black screw on your switch, 13 & 14 go on the other 2 srews on your switch, put 9 & 12 together in your junction box this will go to 6 in your light, 13-7 and 14-8 in your junction box,in your light box put 7-3 together, 8-2 together, and 5 & 1; 2 & 3 go to the gold screws on your switch and 1 goes to the black screw. Damn my head hurts now. lol have fun
wirenut1110 is offline   Reply With Quote
Old 07-02-2008, 04:54 PM   #5
Rewards Points: 109
I had the wrong wire going to the wrong screws on the switches! Thanks for taking the time to number them out...
Thanks,
Chad
Old 07-02-2008, 06:37 PM   #6
joed's Avatar
The black screw is the common screw. It is not in the same position on different brands of switches. You can NEVER go by screw postion when working with three way switches. You ALWAYS need to go by screw colour.
Old 07-03-2008, 07:37 AM   #7
Rewards Points: 109
I did not know that! Thanks... Hay Joed, I was looking at your diagram and was woundering why is it that you went red to white on one of the travelers? I kept looking at it and drew this up. Is this drawling correct?
Old 07-03-2008, 02:10 PM   #8
Rewards Points: 510
Hope Joed doesn't mind me answering, but if you notice, if we kept going the way we were, you'd end up with 2 white wires to hook your fixture to. If you follow the number scheme I gave you, it does the same thing.
Old 07-03-2008, 04:33 PM   #9
joed's Avatar
Colours are limited. You must have a red, white and black between each box unless you are using conduit.
The second drawing has two whites and no black between the fixture and the junction box. The upper white wire needs to be black. So your upper wire will be red black red, which can be very confusing if trying to trace the circuit out. You can't use the black for the neutral at the bottom. It must be white.
I like to use red for switched power. That leaves black for unswitched ower or travellers.
Old 07-04-2008, 07:47 AM   #10
Rewards Points: 109
I didnt even notice that when I drew it up.. Man it looked god too One last question? If I wanted to add a 4 way switch where would I add it and what wires would it go to? Thanks.
Old 07-04-2008, 12:12 PM   #11
joed's Avatar
To add a four way switch you would move one of the threeway to the new location and put the four way in place of the three way. Works with either three way and you can add as many four ways as you need.
The connections would go like this.
Run a new three wire cable to the new switch location.
Remove the common wire and connect to wire of same colour in new cable.
Remove two traveler wire and connect to one set of screws on new four way.
Connect remaining two new wires to other set of screws on four way.
Connect threeway at new location with same wiring as old location.
One option would look like this
Old 07-04-2008, 12:14 PM   #12
Rewards Points: 109
Thank you so much and have a happy forth....
Hay Joed have you ever wired something up so it would show if your garage door was open or closed? Say a very small light or something?
Old 07-04-2008, 02:06 PM   #13
Rewards Points: 506
Send a message via AIM to theatretch85
Oxi, Look at your local home improvement center, they have wireless sensors that indicate the state of your garage door. Little transmitter attaches to the top inside of your garage door and has a sort of float switch inside it so it can sense when the door is open. I think its around 30 bucks and the one i have is made by Chamberlain I believe. If you can't find it locally, try eBay.
theatretch85 is offline   Reply With Quote
Old 07-04-2008, 03:19 PM   #14
joed's Avatar
Never done that but I know they make switches with pilot lights that are used for that. Not the same as a lighted switch and requires a neutral in the switch box.
Old 07-04-2008, 09:28 PM   #15
Rewards Points: 109
Well im kinda interested in building one "Just want to se if I can".... I found an example thats prety coo I think I might go with it but if all else fails I will purchase one. Thanks again for the replys and help
http://www.expertvillage.com/video/4...t-door-two.htm
Oh I found a site that helps with 3-Way Switch varations of how to wire and thought it would be helpfull if someone found this post for help.
http://www.selfhelpandmore.com/switch-outlet/4-way/
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
To Switch loop or not to switch loop beezlebub03 Electrical 7 06-17-2008 06:04 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
