3 Way Switch Help - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2012, 10:51 AM   #1
Rewards Points: 77
3 way switch help
Hi,
I'm trying to hook a 3 way switch back up that I didn't label (my bad). I would very much appreciate any help. I haven't been able to find a diagram on the internet that matches my scenario.
I have two 14-2 cables that go into a switch box. There is also a 14-3 cable that connects this switch box with another switch box.
Then I have two lights that I would like to wire into these 3 way switches
See picture diagram. Please help which wires do I plug into where?
nateo is offline   Reply With Quote
Old 10-27-2012, 11:35 AM   #2
joed's Avatar
Rewards Points: 12,036
It is a good guess the one switch box has a power line, a line tot he fixtures, and a three wire cable to the other switch.
It is most likely wire like this diagram.
The Following User Says Thank You to joed For This Useful Post:
nateo (11-23-2012)
Old 10-27-2012, 05:53 PM   #3
Rewards Points: 258
Older switches are setup differently then the newer ones
redman88 is offline   Reply With Quote
Old 10-27-2012, 06:02 PM   #4
Rewards Points: 2,516
nateo:
On your diagrams...what does it mean when you put "one light is barried" and "this switch is barried"
I have no idea what barried means in relation to the diagrams.
hammerlane is offline   Reply With Quote
Old 10-27-2012, 06:03 PM   #5
both of these diagrams have the power coming into the switch location. See if they help you out. But as you see diagram one shows the traveler cables running thu the light fixture location whereas diagram 2 the traveler cable does not run thru the light fixture location
3 way switch help-1-20sw-20lo-20sw.jpg   3 way switch help-2-20switch-20switch-20load.jpg
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 11:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
