3 Way Switch Help - Electrical - DIY Chatroom Home Improvement Forum
Old 09-07-2011, 08:53 AM   #1
3 way switch help
Newbie to the forum... and really to 3 way switches as well.
I'm having some problems on how to wire a new three way switch system. I have power coming into the first switch, then three lights, then the last switch at the end of the run. I ran 14/3 wire from the first switch, between each light, and then down to the last switch.
The switches are located at opposite ends of the building. Plan was to be able to operate the lights no matter which door I enter.
I've done wiring before, but never three way switches. Looking at several wiring diagrams on line, it seems that what I have done isn't correct. Problem I have is 10 diagrams have 10 different ways of wiring. Some show connecting the switches, then running the lights off of the second switch. Also, it seems that three lights complicate matters.
Thanks a lot in advance.
wyatt880 is offline   Reply With Quote
Old 09-07-2011, 09:07 AM   #2
Licensed electrician
Rewards Points: 1,018
With the way you wired it you would need 14-4 between the lights. Can you still run cables to straighten this out?
I find the easiest way is power into SW1, xx-3 between switches, and from SW2 to L1. No need for hard to find cable and easy to keep the wiring straight.
Old 09-07-2011, 09:21 AM   #3
I can, as nothing is covered up yet. Was hoping to be able to somehow salvage the wire that has already been run.
Can I use two pieces of 14/2 between the lights? If so, how do I run them?
I probably need to put a picture together, as I work better with diagrams than words.
Old 09-07-2011, 10:10 AM   #4
You can just run a xx-3 between the switches. With the xx-3 between the SW2 and each fixture you will just ignore either the black or red.
Old 09-07-2011, 12:02 PM   #5
joed's Avatar
Rewards Points: 11,548
Here is a diagram of how to wire what you have, although it is not the preferred way to do it.
Old 09-07-2011, 01:32 PM   #6
Yes, that's what I was looking for!
Thank you!!
Old 09-07-2011, 03:11 PM   #7
Rewards Points: 1,418
Did you already cut up the 3 wire cable into little pieces daisy chaining from one light fixture box to the next?
If so it is possible you may run into overcrowded boxes if a 2 wire cable is also cut into little pieces and coexist daisy chaining from one light fixture box to the next.
Ideally a 3 wire cable should run directly between the switches. You can leave in place and use the pieces of a 3 wire cable daisy chaining through the boxes for the light connections. Add the direct cable between the switches to the mix. If the best route is up through the ceiling then this additional 3 wire cable can run unbroken past the outside of each light fixture box.
The Following User Says Thank You to AllanJ For This Useful Post:
frenchelectrican (09-07-2011)
Old 09-07-2011, 11:50 PM   #8
" Euro " electrician
frenchelectrican's Avatar
I rather run like what Allen draw have incomming power in first switch then go to next switch then go to the luminaire this is the easiest way to deal with it plus what more it will meet 2011 NEC code without issue at all espcally if you have electrionique timer etc.
Merci,
Marc
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 11:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
