3 Way Switch Help - Electrical - DIY Chatroom Home Improvement Forum
Old 05-01-2011, 12:03 AM   #1
3 Way Switch help
I have a 3way switch atthe end of the circuit. I tried to come off that switch to a 1 pole switch to controll a new ceiling fan that is only going to have one switch. I ran 12/2 wire from that new swith. The 3way still works the same and the new switch turns the power on and off to the the new ceiling fan/light, but nothing happens at the light (nospin and no light). My tester shows the power does get tothe light socket and fan motor. What could be wrong?
BanditParker is offline   Reply With Quote
Old 05-01-2011, 12:27 AM   #2
Scared Electrician
Saturday Cowboy's Avatar
no neutral. the white wire you tapped into at the 3way switch is actually a hot traveler or switch leg (this is legal tho it is supposed to be marked). You can not usually power something else from a switch. try pulling power from a plug.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
