Old 01-31-2013, 01:34 AM   #1
3 Way Switch Circuit Installation Issue
I asked my question here earlier, but my thread got closed as I'm a 'DIYer'.
http://www.electriciantalk.com/f8/3-...87/#post918335
Anyone have any advice that might be able to help even troubleshoot the issue?
Mike Ross is offline   Reply With Quote
Old 01-31-2013, 05:21 AM   #2
Super Moderator
Welcome---Please describe your problem and we will do out best.
Old 01-31-2013, 08:55 AM   #3
joed's Avatar
Please describe in detail the issue and how you wired the switches and lights.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 01-31-2013, 10:33 AM   #4
Hi,
I'm having some trouble getting one of these switches to work in (what I think is) page 2, diagram 3:
http://www.cooperindustries.com/cont...ec%20Sheet.pdf
The switch on the right (I will call it switch 2, wired from traveler) doesn't turn on the light.
I've checked the conductivity of all the wiring and it is good. I'm not sure of is if my black traveler wire is attached to anything else.
Any help or suggestions to figure out why switch two in this circuit doesn't work would be appreciated, thanks.
Old 01-31-2013, 11:25 AM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Originally Posted by Mike Ross View Post
Hi,
The wiring diagram appears to be correct for sensors at both locations are you sure you have the wiring terminated per the diagram?
Old 02-02-2013, 09:38 AM   #6
MarginallyQualified
Does the 1st switch box have a 120V feed in it?
Not switch legs... the H/N/G feed.
That would be very rare to find in older houses...
and very easy to mix up when trying to adapt existing wire to provide it.
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
New Pilot Light Switch - Neutral From Another Circuit OK? appleye1 Electrical 7 03-07-2011 09:23 AM
Ceiling Fan Circuit Problem G_S_DB Electrical 1 08-25-2010 07:24 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
