3-way Switch Arc! - Electrical - DIY Chatroom Home Improvement Forum
Old 04-29-2008, 11:23 AM   #1
Question
3-way switch Arc!
BlaBla
jlaw is offline   Reply With Quote
Old 04-29-2008, 12:08 PM   #2
Power Gen/RS Engineer
Rewards Points: 566
Originally Posted by jlaw View Post
The replacement from lowes was same brand (cooper) but looked like different model(3 rd contact on opposit side)
I'm not sure I understand. Does the replacement switch have 3 terminals (not including ground) or 4?
I did the only thing I could think of, reversed the hot and neutral on the switch. Problem solved! But WHY?
Now here's where I get really confused. You should NEVER have a neutral connected to the switch. The switch legs in a 3 or 4 way circuit are called travellers and are ungrounded. I drew a picture of how the switch may have been miswired and it would explain why you would have a problem with the other switch in one particular position but not the other.
Goofy 3-way.zip
Now the wire colors in the second (i.e. goofed) sketch don't make much sense to my case since it would take a total motorhead to connect two white wires to the switch but electrically, it does match your symptoms.
The only thing that confuses me is that you said the breaker would trip sometimes. In the example I have, it should trip every time the two switches are in the correct positions (switch makes a dead short). And this is when you'd most certainly see the arc.
Jim
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 04-29-2008, 03:16 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Are the breakers arc-fault type?
Old 05-01-2008, 11:51 PM   #4
hms
Remodeling contractor
The "neutral wire" is more than likely the common traveling leg in the circuit. The original installer probably installed it wrong and you copied his mistake.
hms is offline   Reply With Quote
Old 05-02-2008, 12:56 PM   #5
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
BlaBla
I'm confused.
John
jrclen is offline   Reply With Quote
Old 05-02-2008, 03:21 PM   #6
BlaBla
WHY BOTHER?????
This is truly obnoxious!
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
