3 Way Switch Adding An Add'l Light - Electrical - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 04:03 PM   #1
3 way switch adding an add'l light
Hello everyone,
Im trying to add an add'l light in my hall at the other end. I will try to explain in detail as clear as possible. switch one has incoming power. 1)14-3 and 2) 14-2 I think this these goes to two other bedroom lights if your wondering the 2 add'l incoming wires. the 14-3 hookup is red & blk to the double terminals on switch. the single terminal has a pigtail(blk) tied to the other blks from the other 2 incoming 14-2.....whts are bypassed and ties together. Now to the light...light sits right by bathroom is connected from the light to that light switch...2 incoming wires to lights are 14-3... wht from light goes to one of the 1st 14-3 , blk from light goes to the other 14-3 ties to the red. 1st 14-3 blk ties to the 2nd 14-3 wht. Red of the 1st 14-3 tied to the blk of the 2nd 14-3.... 2nd switch has14-3 red on single terminal(bottom) and blk wht on double terminal. I would like to add the add'l light by the end switch. Any help on how to wire would be appreciated and diagrams as well would be better. I hope this is not confusing.
Thanks for everyones time.
GRed is offline   Reply With Quote
Old 12-15-2011, 04:19 PM   #2
Originally Posted by GRed View Post
Hello everyone,
Hope I'm understanding this correctly.
You just need to splice into the Hot and Neutral wires at the current light, as well as the ground, and bring it over to your new light with some 14/2.
fuzzball03 is offline   Reply With Quote
Old 12-15-2011, 04:24 PM   #3
add'l light in hall
Thanks .. I thought this had to be done..wasn't really sure, I was hoping not to go up in the attic...to run that wire from that light over to the new one..geeezzz thanks again..
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
adding new light, to existing switch stiksandstones Electrical 25 03-12-2011 05:50 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Adding a light to a 3-way switch Richo Electrical 3 04-05-2009 10:29 PM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 06:57 PM
