3 Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 02-19-2011, 03:35 PM   #1
3 way switch
I have a light switch in my dining room, and a light switch in my kitchen. I tore down the wall that was dividing both rooms, and on that wall was 2 switches, each switch controlled the dining room and kitchen. Once I tore the wall down, the lights still worked, until I took removed the switch. Now the dining room or kitchen does not have lights. I wired them with the same color, still didn't work. So, now I'm looking around for a electrician on craigslist, but looking to save some money and gain some knowledge on electrical. Here is what we're working with.
There's a copper metal/wiring there, just cant see it.
Dinggus is offline   Reply With Quote
Old 02-19-2011, 04:01 PM   #2
Put the switch back?
You may be able to temporarily get things working again by connecting two of the wires, but I cannot say which ones without seeing the other switches.
What is your intention with these wires? Is your final solution to have only one switch controlling your lights?
oberkc is offline   Reply With Quote
Old 02-19-2011, 04:02 PM   #3
I want to figure out why my lights are not working while the switch is not connected. I'd like to remove them.
Old 02-19-2011, 04:04 PM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Did you put the switch back on those pigtails and it still didn't work?
or are you trying to flip the other switches with these undone pigtails and nothing happens?
tcleve4911 is offline   Reply With Quote
Old 02-19-2011, 04:07 PM   #5
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
This is how your 3 way light switches are probably set up.
Old 02-19-2011, 04:09 PM   #6
Pigtails? I wired them together by color and tried that method, didn't work. So now I just wrapped each one with electrical tape until I can figure it out.
Small picture, but remember I have a light switch in dining room, a light switch by my car port entry way for the kitchen, then 2 switches on the wall that those wires were connected to that controlled the dining room and kitchen.
Old 02-19-2011, 04:14 PM   #7
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Maybe it's a four way...do you have two switches or three switches that control each light?
Old 02-19-2011, 04:24 PM   #8
That might be it. Here is what I have.
Dining room:
Kitchen (Left switch):
The switch I removed:
Old 02-19-2011, 04:30 PM   #9
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
I know you're trying to give as much info you can through the internet, but the pics really don't help ...sorry
Grab a piece of paper, make a quick sketch to show each light and how many switches control each light.
Just a simple line for the wire
Don't try to draw the red, black & white like a diagram.
Take a snapshot and post.
Then I think we can really help
Old 02-19-2011, 04:52 PM   #10
On the phone with a friend from California, he's trying to help me out as well.
Old 02-19-2011, 04:54 PM   #11
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
okay...now draw each light and then draw a line from each switch to each light
Old 02-19-2011, 04:59 PM   #12
Do you have a volt meter? Any way to identify voltage?
Old 02-19-2011, 05:02 PM   #13
I have a voltage detector pen, and no volts are going to the switches or lights.
Dining:
Kitchen:
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
