3 Way Switch - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-27-2010, 11:35 AM   #31
3-way switch diagrams
I can't tell you what you have without looking at the wires in the boxes.
Here is a great link to all the ways a 3 way can be hooked up.
http://www.homeimprovementweb.com/in...way-switch.htm
When you purchase a 3-way switch there is a basic wiring diagram inside. Printed on the box.
Are the boxes metal? If so the ground/bare wires are bonded to the metal box.
Hope this helps
Bob
Hourglass52 is offline   Reply With Quote
Old 12-28-2010, 05:08 PM   #32
3-way
Here is a cool video that explains how the e-way switchs works.
http://www.electrical-online.com/vid...-way-switches/
Old 12-28-2010, 05:10 PM   #33
Originally Posted by joed View Post
You've come this far. You should be able to finish this.
At the switch box remove the white pigtail to the three way.
Make sure the black pigtail is on the common screw(black one).
Put the other black and red to the other two screws.
At the fixture connect the two reds.
Connect the white from the double switch box to the fixture.
Connect the black from the second switch to the fixture.
At the second switch connect the black to the common\
Connect the red and white to the traveller screws.
ok what to do with the wires on the single pole in box 1?
Busta1n2 is offline   Reply With Quote
Old 12-28-2010, 05:30 PM   #34
Scared Electrician
Saturday Cowboy's Avatar
the photo I modfied and posted on the last page, should include all wiring needed. Is there something I missed or is unclear. Please let me know where we now are with this and we will try to guide you form there.
Saturday Cowboy is offline   Reply With Quote
Old 01-25-2011, 06:27 PM   #35
Sorry it took so long to get back with an update but here it is. Ended up reaching put to a friend of a friend and he was scratching his head for some time. When I said the one magic word it was like a light bulb came on. One of the old switched had a light in it and that was what was messing me up the whole time because the new switch did not have a light. Long story short we have it all fixed and everything works. Thanks to everyone for all the help.
Tags
3 three way switch
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
