3 Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2010, 04:49 PM   #1
3 way switch
Can someone tell me if I wire a 3way circuit with 2 lights the same way as if it was 1 light thank you wizz
wizz is offline   Reply With Quote
Old 09-02-2010, 04:57 PM   #2
Rewards Points: 869
yes, you do. you just wire the second light in parallel to the first. i.e. continue the hot (blk) and neutral (wht) & ground wires from the first light to the second.
TimPa is offline   Reply With Quote
The Following User Says Thank You to TimPa For This Useful Post:
wizz (09-02-2010)
Old 09-03-2010, 11:36 AM   #3
joed's Avatar
Rewards Points: 13,354
Depends on the configuration. If you are trying to put the two lights between the switches then you need four wires between the lights.
If you wire it up as one light then tap off that one light to the additional light no problem.
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
