3 Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 05-09-2010, 04:38 PM   #1
Question
I am trying to eliminate a 3 way switch. The left over switch won't work and I have tried to wire as a single, but it still won't work. What should I do now?
I am trying to eliminate a 3-way but can't get the left over one to work. What am I missing???
walt-d is offline   Reply With Quote
Old 05-09-2010, 04:51 PM   #2
Are you just taking the switch out of the box or removing the assocated wiring also? If you are just taking the switch out of the box, you need to wire nut two of the wire together in the box that the switch came out of.
studhauler is offline   Reply With Quote
Old 05-09-2010, 04:55 PM   #3
which 2 wires to nut together??????
Old 05-09-2010, 05:02 PM   #4
Licensed electrician
Rewards Points: 1,634
There are several ways that a pair of three ways can be wired. You would need to figure out how they were wired before trying to remove anything.
Old 05-09-2010, 05:13 PM   #5
there are three wires. black, red and white. Which do i wire together and still have the left over switch work?
Old 05-09-2010, 05:15 PM   #6
are there any other wire in that box?
Old 05-09-2010, 05:17 PM   #7
No there isn't
Old 05-09-2010, 05:17 PM   #8
The red and the balck OR the red and the white. Depending on which way you want your other switch to work.
Old 05-09-2010, 05:20 PM   #9
I just want to be able to turn the light on as if there wasn't the other switch available.
Old 05-09-2010, 05:28 PM   #10
Depending on which color combo you go with will determine if "up" is "on."
Old 05-09-2010, 05:28 PM   #11
With 3 wires coming out of your box and one jumper, there are 3 ways to put the jumper between two wire ends. With each jumper position, flip the remaining switch to both positions.
Only one way doesn't work, so on your first or second try it should work. If not, more tests are needed.
For no drama, use an incand. bulb for the jumper and have the same size incand. as the controlled light. When both lights glow dimly this is the 'on' position.
If your jumper light glows full brightness do not use a jumper wire between these two wire ends; more tests are needed.
Old 05-09-2010, 08:28 PM   #12
Just call me Andrew
Rewards Points: 1,020
Do you plan to cover up the old switchbox with a drywall patch? If so, you cannot do so. You'll need to put a blank cover plate over the box where the removed switch used to be.
Andrew
secutanudu is offline   Reply With Quote
Old 05-09-2010, 09:35 PM   #13
Sounds like this is a dead end three way. All the OP needs to do is remove the wiring from the other switch and configure those wires ath the switch that is staying and install a single ole switch. No need for any light bulbs or jumpers.
Old 05-10-2010, 01:28 PM   #14
I have aready tried this, and it didn't work. black to gold and white to silver but didn't know what to do with the red so I tucked it away. This didn't work. What now?????????? What should I do with the wires from the deleted switch.
Old 05-10-2010, 02:34 PM   #15
With the wires from the deleted switch, try black to red, if that don't work, try white to red. This assumes you didn't change anything in the good switchbox.
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
