3 Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2009, 07:15 PM   #1
3 way switch
I want to install 2 additional flourescent fixtures in my garage. I have a 3 way switch by the garage door where I would like to get my power. The other 3 way is up front by my kitchen.
I want to install one plug-in for both for both of my fixtures in the ceiling using the 3 way switch by the garage door for power. Is this possible and if so, how?
Thanks for your help.
Mike
mike pace is offline   Reply With Quote
Old 05-04-2009, 08:34 PM   #2
Remodeling Contractor
you will need to see which switch has power. Many times the power is at one switch and the switch leg to control the lights is at the other.
Old 05-04-2009, 10:10 PM   #3
Is it possible to tap off the existing light fixture that is on the 3 way system? That would be much easier for wiring and for the most part foolproof.
unclduey is offline   Reply With Quote
Old 05-04-2009, 10:26 PM   #4
joed's Avatar
Rewards Points: 11,610
You can always tap off the existing fixture for addtional fixtures in a three way. Some times you can tap off one of the switches.
When tapping off the existing fixture use only the two wires connected to the existing fixture and leave any other wires in the box alone.
Old 05-05-2009, 11:33 AM   #5
3 way switch
I cannot run a feed from existing fixtures unless I run it on the outside of my ceiling. There is an I beam between the existing and proposed new lights. I was trying to keep it neat but this may be my only option.
I have run the two wires from the existing 3 way switch to the new lights and they do not come on. I do know much about wiring but I think I may have to run a wire from my 3 way in the kitchen to the new fixture. This would be hard to do so I may have to plug into the exisiting fixture and tack the wire to my ceiling and not be so neat.
Thanks for all the help and suggestions.
Mike
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 02:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 06:53 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
