3 Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 10-02-2006, 12:37 AM   #1
3 way Switch
I have a 3way setup as per my diagram, that is working correctly.
My question is, can I hook up another switch (with light) as per my diagram? I have it setup this way right now and the second switch/light combo only works when i have the first 3way in one possition, which i now understand why. Is ther another way i could hook this up, or do i have to run power over to the second switch?
any help would B great.
jeepwillies is offline   Reply With Quote
Old 10-02-2006, 04:07 AM   #2
You need to run power to the new switch.
jwhite is offline   Reply With Quote
Old 10-02-2006, 06:34 PM   #3
joed's Avatar
Rewards Points: 13,308
You can't make it work independent of the 3ways unless you go back to the first switch for unswitched power.
Old 10-02-2006, 07:15 PM   #4
Electrician
Rewards Points: 800
Are you wanting to control the second light seperetly, if so you have no choice but to go back to the first switch and get power.
Or are you trying to control both lights from all three locations, if so you will need to use a 4way, if this is what you are doing let us know and we will give you instruction on how to do that.
Darren
darren is offline   Reply With Quote
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
New Switch / Ceiling Fixture - Help nelrolo3 Electrical 1 03-12-2004 06:11 PM
