3 Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2013, 08:15 AM   #1
Rewards Points: 240
3 way switch
yeah, i know its been asked a million times. but i get nervous doing things i am not sure about.
so
is this a correct way to do it ?
http://www.wikihow.com/Wire-a-3-Way-Light-Switch
also. are 3 way dimmers good ? as in reliable.
Fix'n it is offline   Reply With Quote
Old 09-16-2013, 08:55 AM   #2
MarginallyQualified
Rewards Points: 2,464
[QUOTE=Fix'n it;1242234
so... is this a correct way to do it ?[/QUOTE]
There are about 10 correct ways
Old 09-16-2013, 09:23 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,258
I usually run power to the first switch box, 2 wire cable from the second switch box to the light and a 3 wire cable between the switches. Run 4 wire cable if your code cycle requires a neutral at all switches.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 09-16-2013, 09:24 AM   #4
Rewards Points: 240
wow, no kidding, well then. how does a guy decide which one to use ?
i need something "bonehead proof".
Old 09-16-2013, 09:25 AM   #5
Rewards Points: 240
i don't have any 14/4. only 14/2 and 14/3
Old 09-16-2013, 09:27 AM   #6
Rewards Points: 240
oh. i am 2002 code.
Old 09-16-2013, 09:41 AM   #7
Rewards Points: 240
learning more.
i am going to be using "switch-fixture-switch''.
Old 09-16-2013, 10:12 AM   #8
Rewards Points: 240
learning even more. and i have an issue.
layout :
left switch. right switch with incoming power. light 14/2 comes down to the right switch.
i can't find a diagram for this. all i find is the power coming in the left switch. it can not come into the light in this app.
Old 09-16-2013, 12:22 PM   #9
I suspect most folks choose the correct method based upon minimization of electrical cable, or ease of access. If that is not a concern of yours, then use the one shown in the wiki.
Personally, I am a fan of having a neutral at each switch box as suggested by rjniles. If you want or need (may be code in your area) this, then the wiki would need updated to have a four-conductor cable between fixture and second switch.
oberkc is offline   Reply With Quote
Old 09-16-2013, 04:33 PM   #10
A "Handy Husband"
rjniles's Avatar
How does one decide: a consideration is "box fill". Look at the boxes that you are using for capacity and see how many cables you plan on each box. Is the capacity large enough to meet code?
The reason I like my method is that it minimizes the number of wires in each box.
I really dislike bringing the travelers through the fixture box as it makes trouble shooting difficult.
The Following User Says Thank You to rjniles For This Useful Post:
Jim Port (09-19-2013)
Old 09-18-2013, 08:57 PM   #11
Rewards Points: 240
i found what i was looking for. if you guys see a problem, PLEASE speak up.
http://hometoys.com/htinews/feb98/ar...ngery/fig2.gif
box fill. doesn't matter. as i can easily put any box needed.
Old 09-19-2013, 04:49 AM   #12
A "Handy Husband"
rjniles's Avatar
Electrically that diagram is fine but it shows a 3 wirecable with a red and 2 blacks. That cable does not exist: a 3 wire cable has a red, black and white.
Also it does not meet the 2011 NEC requirement to have a neutral in each switch box.
Old 09-19-2013, 06:13 AM   #13
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
It's simpler if you just feed one 3-way, and take the load out of the other 3-way, this way you have a neutral at every switch box....
The Following User Says Thank You to stickboy1375 For This Useful Post:
rjniles (09-19-2013)
Old 09-19-2013, 07:28 PM   #14
Rewards Points: 240
thanx. that is probably just a typo. i can mark the white black if needed.
i am under nec 2002.
how would a neutral be wired in ?
basicly i need that configuration. or else i am running extra wires.
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
A few wiring questions on installing this timer switch thinksincode Electrical 19 03-04-2013 05:31 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
