3 Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2013, 07:04 PM   #1
3 way switch
How would a 3 way switch be wired if there are 3 = 12/3 lines coming into the box?
chonchonater is offline   Reply With Quote
Old 04-05-2013, 07:11 PM   #2
Electrician
Rewards Points: 150
Exactly the way the old switch was wired. Because you very carefully marked and labeled the wires and drew a schematic when you took it apart, right?
Do you have any kind of tester to determine if a wire has voltage? What kind?
Glennsparky is offline   Reply With Quote
Old 04-05-2013, 07:42 PM   #3
3 way switch
It's new wiring and it is not connected to the panel yet. The line coming in is red, black, white and ground, the 2nd line also has red, black, white and ground is going to a ceiling fan, The 3rd line also has red, black, white and ground is going to the other 3 way switch. Any suggestions?
Old 04-05-2013, 08:34 PM   #4
Rewards Points: 512
Here's one method: If your cable runs are different from these, then there will need to be some changes.
This has the source to the first 3-way switch, with a 14/3 between switches, and 14/3 between S1 and Fan.
Does your fan have a light?
Old 04-05-2013, 09:05 PM   #5
3 way switch
Yes it does, WOW !!! excellent diagram.I have a few questions...If I have a black,red, white and ground coming in do I just cancell the red wire? Also the white wire gets joined together with the white wire going to the light right?
Old 04-05-2013, 09:09 PM   #6
3 way switch
what if I would like to put 2 ceiling fans with lights between the 3 way switches?
Old 04-05-2013, 09:13 PM   #7
Rewards Points: 512
yes and yes. Did you install the 3-wire from the panel, or was it existing?
Old 04-05-2013, 09:14 PM   #8
Rewards Points: 512
lol, too late in the evening for me on that one, but yes, it can be done. I'll hand that over to one of those who do it everyday
Old 04-05-2013, 09:23 PM   #9
3 way switch
new wire from the panel but it is not connected yet.
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
A few wiring questions on installing this timer switch thinksincode Electrical 19 03-04-2013 05:31 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
