Old 10-26-2012, 08:25 PM   #1
3-way switch
my problem is not in the switch itself but up in the electrical box in the ceiling.there are 4 different set of wires coming into the box ,each with a black,white,and bare wire. Do i hook the blacks together and the whites together? Because when doing so the lights come on but the wall switch will not work or will trip the panel breaker. thks
kevin french is offline   Reply With Quote
Old 10-26-2012, 08:50 PM   #2
joed's Avatar
3-way switch
Then I guess that is not correct. You need to determine where each set of wires goes and post back. Then we can tell you how to connect them.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 10-26-2012, 11:26 PM   #3
3-way switch
You most likely have one of 4 situations for your 3-way switch/light configuration:
1. power into switch location----light----other switch location
2. power into switch location----other switch location----then light
3. power into light location-----traveler cable to switch----- traveler cable to other switch
4. a variation of #3 but here the traveler cables for the switches are run to/from the light location
do not get to hung up on the color of the wire insulation in as much as the function of the wire. like joed suggested You need to determine where each set of wires goes and post back
I do not show any ground wires just for ease of drawing. Also guess my drawings did not post in numerical order.
hammerlane is offline   Reply With Quote
Old 10-26-2012, 11:31 PM   #4
Licensed Electrician
k_buz's Avatar
3-way switch
Why did you take them apart?
Not a fan of the new layout.
Old 10-27-2012, 02:23 AM   #5
" Euro " electrician
frenchelectrican's Avatar
3-way switch
Did you take a look at the switch itself to see what colour the conductor and the numbers as well ??
To sort this out you will need a basic DVM ( digital volt meter )
First of all seperated all the conductors do not let any of them touch each other and turn the power on and find which one is incomming source then turn the breaker or remove the fuse and mark that one then switch the DVM to the ohm scale and find the switch pair you will have to play with this a little to find which one is the switch loop.
And post it back we will go from there.
The three way switch loop will have black et red et white conductors and be aware not all the white is used for netural conductor at all. < that have to be remarked >
Merci,
Marc
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 11:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
