3 Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-18-2012, 01:21 PM   #1
3 way switch
why cant i turn light off and on at any switch? if i turn on light at point A turn off at B, shouldnt I be able to go back to A ?
purplejoyjoy is offline   Reply With Quote
Old 09-18-2012, 01:50 PM   #2
sounds like you have something miswired. the current place im staying at has a 3way switch at the top and bottom of the stairs and i can turn the light on or off at either switch.
firsttimeremode is offline   Reply With Quote
Old 09-18-2012, 01:55 PM   #3
some wires are switched on one or both of the switches
Old 09-20-2012, 06:57 AM   #4
Rewards Points: 1,548
Check for loose connections.
Did you install it yourself?
Did it ever work?
Old 09-20-2012, 07:51 AM   #5
joed's Avatar
Rewards Points: 13,718
One or both of the switches are miswired. Tell us all the wire connections in all the switch boxes. Leave out the grounds.
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
