3 Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2011, 01:41 PM   #1
3 way switch
OK another question.
I want to put in a 3 way switch, one dimmer and the other just a switch (3-way).
Let's see if this makes sense...... I have a my 14/3 running from one wall to the opposite wall, via the ceiling. I have a round box in the center of the ceiling, this is where the power comes in an where I would have the light (and my 14/3 runs by).
Is it possible to tap into the power in the center of my new 14/3 wire? And does this make sense?......lol
Tboy is offline   Reply With Quote
Old 11-26-2011, 01:58 PM   #2
Licensed electrician
Rewards Points: 1,762
If the cable is only between the switch locations what power are you trying to tap into? The power switches between the legs of the travelers/
Old 11-26-2011, 03:49 PM   #3
joed's Avatar
Rewards Points: 13,308
Is this what you are trying to describe?
Old 11-26-2011, 03:53 PM   #4
Thank you joed!!! That is it.
Old 11-28-2011, 02:23 PM   #5
The drawn image is pretty much the same as Joe one above, I have wired it this way and it only works if the 3-way switch is in a certain position. The make of make of the dimmer is Leviton, there are 2 red wires, 1 black and a ground.
Old 11-28-2011, 03:47 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
You have the travelers and a common mis-wired at one (or both) of the switches.
Coastal South Carolina
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
