Old 02-08-2008, 12:56 PM   #16
3 way smart dimmer issue
Goose134: Regarding your advice to 3-way dimmer wiring: Can I connect a sliding 3-way dimmer from powered junction box to a standard 2-way remote switch? Dimmer functions normally but will not function if remote switch is activated. I do not need dimmer function at remote location. Do I need to install a 3-way switch at remote location? Thanx!
gronk is offline   Reply With Quote
Old 02-10-2008, 02:27 AM   #17
Lic. Master Electrician
2-3way dimmers tied in together for the same light fixtures will not work. Replace one of the dimmers with a regular 3 way and you should be ok. Also, the diagram on post #9 is showing wiring of a 3 way to a single pole switch. This wiring is incorrect to operate lighting from 2 locations.
idoelectric is offline   Reply With Quote
3 way dimmer ? DIY4EVER Electrical 1 11-12-2007 10:04 PM
Heating Issue! not mechanically inclined HVAC 3 11-09-2007 10:40 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
OK to user a dimmer with ceiling light? FreeCashBack.co.uk Electrical 2 06-19-2005 10:16 PM
