3-way And Single Pole Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 08-23-2011, 07:34 PM   #1
3-way and single pole switches
how do i get power from a 3-way switch to a single pole switch
doreian is offline   Reply With Quote
Old 08-23-2011, 07:42 PM   #2
Licensed electrician
Rewards Points: 1,480
You would need to determine if there is a constant hot at that 3 way. If so you would add two pigtails to the constant hot. One will provide power to each switch.
You also need a neutral in the switch box.
Old 08-23-2011, 07:47 PM   #3
Rewards Points: 6,652
If you whistle, it will happen. It is just magical how it happens.
