3 Way As Power Source For New Light - Electrical - DIY Chatroom Home Improvement Forum
Old 02-09-2012, 01:56 AM   #1
3 way as power source for new light
Sometimes a picture is worth 1,000 words, so please see the attached.
I'd like to use an existing 3-way switch as a source of power for a new switch & light. I do not want the existing 3-way switch to control the new light. I was initially thinking I could simply pigtail both the existing red and white wires to the new white, figuring that either the old red or white would always close the circuit (but not both at the same time),,, but it's getting late and I'm now thinking I was wrong.
Let me know if this can be done,,, if it can't, I can potentially run a line from a nearby unswitched outlet.
Thanks.
HBG_Don is offline   Reply With Quote
Old 02-09-2012, 03:49 AM   #2
Julius793's Avatar
If I understand you then the answer is no because what your inherently doing is connecting the travelers.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-09-2012, 07:00 AM   #3
Licensed electrician
Rewards Points: 1,788
If this 3w is where the power enters that part of the circuit you can do this but differently than you planned. Is there another cable in the box that supplies power to the switch?
Old 02-09-2012, 07:42 AM   #4
joed's Avatar
Rewards Points: 13,356
If the three way switch only has three wire + ground then you do not have a neutral wire. You can NOT tap power from the switch.
Old 02-09-2012, 07:52 AM   #5
power enters the 3-way circuit elsewhere
Unfortunately no. The power enters the circuit at either the light or the other 3-way switch.
Tags
3 way switch , new light fixture help , power , single pole
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Power strip hack salex Electrical 3 01-31-2012 06:10 AM
No Power to Light Switch! rinky Electrical 13 01-27-2012 07:16 AM
Wiring multiple lights between power source and switch j2m Electrical 3 10-03-2010 07:29 PM
No power to light fixtures or switch in garage mrsirmrman Electrical 5 09-29-2010 03:36 PM
