-   -   3 way as power source for new light (http://www.diychatroom.com/f18/3-way-power-source-new-light-133109/)
HBG_Don 02-09-2012 02:56 AM
1 Attachment(s)
Sometimes a picture is worth 1,000 words, so please see the attached.
I'd like to use an existing 3-way switch as a source of power for a new switch & light. I do not want the existing 3-way switch to control the new light. I was initially thinking I could simply pigtail both the existing red and white wires to the new white, figuring that either the old red or white would always close the circuit (but not both at the same time),,, but it's getting late and I'm now thinking I was wrong.
Let me know if this can be done,,, if it can't, I can potentially run a line from a nearby unswitched outlet.
Thanks.
Julius793 02-09-2012 04:49 AM
If I understand you then the answer is no because what your inherently doing is connecting the travelers.
Jim Port 02-09-2012 08:00 AM
If this 3w is where the power enters that part of the circuit you can do this but differently than you planned. Is there another cable in the box that supplies power to the switch?
joed 02-09-2012 08:42 AM
If the three way switch only has three wire + ground then you do not have a neutral wire. You can NOT tap power from the switch.
HBG_Don 02-09-2012 08:52 AM
power enters the 3-way circuit elsewhere
Unfortunately no. The power enters the circuit at either the light or the other 3-way switch.
