3 Way OCC Sensor - Electrical - DIY Chatroom Home Improvement Forum
Old 06-22-2010, 03:54 PM   #1
3 way OCC sensor
I would like to install 2 OCC sensors to replace 2 3way switches. Can 2 single pole OCC switches wired in series work? The switches are at the top and bottom of a stairs, so both OCC sensors must function.
Jessie12 is offline   Reply With Quote
Old 06-22-2010, 05:44 PM   #2
The SP switches should be in parallel to get an OR function, and that assembly in series with the source and the load. If either one or both are on the light will then be on. This is assuming the sensors present a pair of contacts that close, just like a wall switch.
Do you have a link to the sensors?
Old 06-22-2010, 10:46 PM   #3
P&S also makes a "3-way" sensor. Most wall sensors can be wired in parallel like Yoyizit said, but this product is leaded specifically to be easy to install in a 3-way application.
Link: http://www.legrand.us/PassAndSeymour.../RW3U600W.aspx
You have quite a few options though, because you can just wire in parallel and pick a sensor you like.
brich is offline   Reply With Quote
Old 06-23-2010, 12:55 PM   #4
And in the link, the max lamp you can use is 1/6 hp, ~120w.
Old 06-23-2010, 01:54 PM   #5
Licensed electrician
Rewards Points: 1,618
That sensor is good for 600 watts according to P&S, not 120 watts.
Ideal for storage and utility areas (garages,
laundries, closets, pantries, etc.)
Hands-free convenience.
RW500U (25W to 500W), no neutral required;
RWU600U (600W), neutral required.
From a pdf linked from this page.
http://www.legrand.us/PassAndSeymour/Lighting-Controls/Residential/Residential-Sensors/Single-Pole-3-Way-Occupancy-Vacancy-Sensor/RW3U600W.aspx
Ruud furnace issue on upgrade board and flame sensor rubberman HVAC 23 11-05-2014 12:36 PM
Cooper Motion Sensor Help needed please scoops Electrical 3 02-23-2012 10:39 PM
Installing 3-way occupancy sensor westbank Electrical 6 05-04-2010 05:08 PM
Wiring Motion Sensor Electronic Lighting Switch consultant Electrical 2 03-07-2010 07:19 PM
Occupancy Sensor: Did I wire it correctly? kohaiut Electrical 7 01-14-2009 10:13 PM
