3 Way Motion Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 02-19-2011, 11:34 PM   #1
try,screw up,learn
3 way motion light switch
Hello,
I just installed a 3 way motion switch in my kitchen after intense research i was able to find the way the wires were ran.
power throught light fixture and than to the 2 switches (see attached photo)
it powers a light and fan fixture in kitchen
now my problem is when the motion switch is in auto mode and just the lights are on i hear humming or buzzing from the breaker box and motion switch
when the fan is on with the lights no buzzing
when the switch is set to just on no buzzing
when just the fan is on but i pull the string to shut off just the light no buzzing
i have those energy effecient florecent bulbs in the fixture 3 60 watt
the motion switch is 500 watt rated 3 way
square d panel with a 20 amp breaker
any comments on why there is a humming sound?
souciej is offline   Reply With Quote
Old 02-20-2011, 11:21 AM   #2
Scared Electrician
Saturday Cowboy's Avatar
those switches are not designed to use CFLs. Install old fashion bulbs.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
The Following User Says Thank You to Saturday Cowboy For This Useful Post:
souciej (02-20-2011)
Old 02-20-2011, 11:58 AM   #3
try,screw up,learn
is it bad to leave those bulbs in do i have to worry about that humming or if i can ignore it is it safe? i was always told humming was moving parts, moving parts generate heat, heat make fire so just double checking here?
Old 02-20-2011, 03:27 PM   #4
Scared Electrician
it will cause premature failure if anything. I would not recommend leaving the situation as is
Old 02-20-2011, 03:34 PM   #5
try,screw up,learn
well just got back from lowes and i took out the CFL's and put in the old style bulbs and the humming stop i guess if ur trying to go green be selective of what you want the switch or CFL's thanks cowboy for the suggestions
Old 02-20-2011, 09:33 PM   #6
Electrical Supplier
Rewards Points: 150
As a reference to future readers, a rule of thumb is that if there is NO neutral on an electronic switch (motion or timer etc) it is NOT designed to be used with ANY fluorescent lamps, either linear or CFLs.
You need to find a 3 way motion switch that has a neutral if you want to use CFLs.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 02-20-2011, 09:53 PM   #7
try,screw up,learn
lyons i thought i did buy the right one on the package it said 3-way motion switch used for up to 500 watts of incandecent or 400 watt of fluorescent lighting of 2 tubes min. requies magnetic ballets only. what does that mean ?is my wiring wrong?
Old 02-21-2011, 12:45 AM   #8
Scared Electrician
AHH HA! Yes that would allow you to use florescent because there is a device(read old school ballast) that hides them from the switch in this case. It would only work with old ballasts and most are not now and CFLs
Old 02-21-2011, 01:55 AM   #9
" Euro " electrician
frenchelectrican's Avatar
It depending on what type of luminaire I know with ceiling fans the trick I do is install one indenscent bulb the rest with CFL that useally take care the issue but really I rather do the correct way by double check the listing on the package when you get the motion switch etc.
Merci.
Marc
installing a motion sensor light on a two way switch dwittekind Electrical 3 08-11-2010 08:19 AM
Security Light/ Motion Light Question williamj001 Electrical 3 01-11-2010 11:30 AM
motion, photosensor, light switch to choose mode joshoc Electrical 5 12-18-2009 12:49 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
