Old 05-29-2005, 07:00 PM   #1
Question
3-way lights in basement
johnson217@netzero.com
I am wiring two banks of lights in my basement. Each will operate with 3-way switches. I want them to run on one circuit. I have the wire from the panel running to a junciton box where I plan to connect one switch from eahc of the separate light banks. Will this work?
Could I then connect the lights directly from the junction box or do I need to splice from the switch?
johnson217 is offline   Reply With Quote
Old 06-01-2005, 07:18 AM   #2
Electrical Contractor
The best thing to do is run the hot to the switch box, pigtail your two hots to your switches, then run the switch wires to the first light then jump to each light from there.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
jbfan is online now   Reply With Quote
More On This Topic
Hi, I am Albert Headsmith with Expert Village. We are going to talk a little bit about basic trailer. Now, we are going to talk a little bit about hand signals. If you are driving a smaller trailer without an electrical system it is important to know... Read More »
Trailer Weight Capacity
Trailer Weight Capacity by Expert Village
Hi, I am Albert Headsmith with Expert Village. We are going to talk a little bit about Basic Trailer. Let?s talk a little bit about weight loads and how much a trailer is actually able to carry. It's really a good point to go and look at the tag that is... Read More »
Hi, I am Albert Headsmith with Expert Village. We are going to talk a little bit about basic trailer. One of the first things that you do once you get your trailer set up and actually hooked up the car is you want to go ahead and adjust your mirrors so... Read More »
Hi, I am Albert Headsmith with expert village. We are going to talk a little bit about basic tailoring. Right now what we are going to explore is actually how to hook up the trailer to the vehicle. The first thing that you are going to want to do is to... Read More »
Hi, I am Albert Headsmith with Expert Village. We are going to talk a little bit about basic tailoring. Right now we are going to talk about some basics of driving a trailer. One of the first things that you have to remember is that it is just like... Read More »
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
How to 'start' finishing the basement... mcvane Building & Construction 18 06-04-2007 09:28 AM
Wet Basement being fixed (pics) harleysilo Remodeling 2 01-23-2007 09:09 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
