3 Way Light Switch Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-20-2015, 06:36 PM   #1
Rewards Points: 8
3 way light switch question
Hi, I hope someone here can help me.
I have an existing 3 way light switch on a staircase, with power coming into one of the switches, and then 2 lights between the switches. I does not work properly because it does not have the second run of 2 wire between the lights. But I just ran across a diagram that would solve my problem, if it works. I took it from google images, so I do not know the original source. I did a quick tweak of recoloring a couple of wires to correct an issue that was pointed out on the image.
So my question is, will this actually work? No one else has a diagram like this, so I am wondering what the flaw here is. I really want this to work.
hyena65 is offline   Reply With Quote
Old 01-20-2015, 06:54 PM   #2
Rewards Points: 1,418
Will not work. You have the two light bulbs connected "in series" where each 120 volt bulb gets 60 volts.
You must run the additional 2 conductor (plus ground) cable between the two lights. Connect it to the light fixtures, matching white to white (to silver screws) and black to black (to gold screws). At the first light box connect the power cable white to the light neutral (with the white wire already attached). Connect the yet unused wire coming from the 3 wire cable between the lights to the light hot (with the new black attached).
Nitpicking. The wires connected to the neutral terminals of the lights may not be colored. The wires connected to the hot terminals of the lights may not be white. Putting tape around the ends of these wires will not get around this.
The Following User Says Thank You to AllanJ For This Useful Post:
Robpo (01-20-2015)
Old 01-20-2015, 07:33 PM   #3
Rewards Points: 8
Ya, I know that, but I am not tearing out 2 walls to run a second wire. Trying to come up with a solution that does not include removing one fixture.
So next question. With the new LED bulbs that require lower voltage anyway, is there still a problem with power drain?
Old 01-20-2015, 07:55 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
it's not a matter of power drain. It's a matter of Ohm's law. When you run load in series you "drop" an amount of voltage inversely proportionate to the resistance of the load.
lets say both lights are exactly equal as far as resistance. That would mean, as allenj stated, you would have 60 volts "dropped" or for a more understandable term, available at each light. On top of that, if either light burns out, both stop working.
If you have lights rated for 120 volts, you have to have 120 volts to the light.
how about making a diagram of what you actually have in the system
Old 01-20-2015, 08:15 PM   #5
joed's Avatar
Rewards Points: 11,516
The only solution that does not involve more wires or removing one of the fixtures is to use wireless three way switches.
Old 01-20-2015, 08:23 PM   #6
Rewards Points: 8
Honestly, I'm not sure what exactly is in the system. I just bought the house (1895 Victorian rewired in 1987) and this 3 way just doesn't work. The 2 fixtures are not that accessible, so I am hesitant to risk falling down the stairs for just a look-see. (servant's stairs, very narrow, very steep both fixtures over bends with triangular steps, and I'm short.)
The seller had an electrician spend a couple hours fiddling with it, and his conclusion, will never work, doesn't have the second line between fixtures. Right now, if I turn on the lower switch, then I can turn on/off at upper switch. If lower switch is off, nothing works. I am assuming that there is 3 wire between all the pieces.
I am just searching for ideas to make at least 1 fixture work properly. I also can add an option to have second fixture with a switch on the fixture, if that helps.
Baring any good alternatives, I'll just remove one fixture. And that is looking more and more likely.
Oh, Joed, I guess you posted while I was typing. Interesting idea, I didn't know there was such a thing. I will look into that.
Simple Question on Light Switch Series hagler Electrical 19 03-20-2012 08:46 AM
3 way switch -OK to drop down neutral like this to light through switch box via 12/3? darlingm Electrical 9 12-22-2011 03:48 PM
2 Wires in to light, 3 Wires out, no juice on the switch prytoo Electrical 4 11-28-2011 06:24 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
A simple 2 light --1 switch question? redondo11@msn.com Electrical 7 11-05-2008 09:35 AM
