3 Way Light Circuit, Middle Load, Neutrals In Switch Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-16-2012, 08:43 PM   #1
langless28's Avatar
Rewards Points: 152
3 way light circuit, middle load, neutrals in switch box?
With the nec requiring a neutral in all switch boxes, would you need a 4 wire with ground for the switch at the end? Or if I'm wrong how does that work?
langless28 is offline   Reply With Quote
Old 10-16-2012, 09:32 PM   #2
Rewards Points: 1,512
If you run the power to the switches first and then to the light, you have neutral in all the switch boxes and avoid the need for 4 conductor cable.
However, for a switch beyond the light, I would cautiously try a 2 conductor cable plus a 3 conductor cable in lieu of of one 4 conductor cable, depending on what supplies I had on hand.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
SPDT switch, 3 way light switching circuit pintree3 Electrical 5 11-06-2011 12:40 PM
Basement lighting circuit - multiple lights and switches, end of circuit cmyk Electrical 2 03-03-2011 02:39 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
Adding 15 amp light and switch on a 20 amp circuit Jzack26 Electrical 1 08-02-2009 04:02 PM
