-   -   3 way light circuit, middle load, neutrals in switch box? (http://www.diychatroom.com/f18/3-way-light-circuit-middle-load-neutrals-switch-box-160327/)
langless28 10-16-2012 08:43 PM
With the nec requiring a neutral in all switch boxes, would you need a 4 wire with ground for the switch at the end? Or if I'm wrong how does that work?
http://2.bp.blogspot.com/_YDwC2Rs77N...RI8/s400/c.jpg
AllanJ 10-16-2012 09:32 PM
If you run the power to the switches first and then to the light, you have neutral in all the switch boxes and avoid the need for 4 conductor cable.
However, for a switch beyond the light, I would cautiously try a 2 conductor cable plus a 3 conductor cable in lieu of of one 4 conductor cable, depending on what supplies I had on hand.
