3-way Illuminated Switch - Voltage Present - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-15-2008, 07:51 PM   #16
Originally Posted by Silk View Post
Can I choose "All the Above"?
I don't see why not. . .
But I've never been all those things at the same time.
What is your procedure for troubleshooting 3-way switch setups (with a Wiggie, or not)?
Old 11-29-2009, 12:56 PM   #17
I am running in to the same problem.
My garage is wired for 3 switches which worked properly with a CFL bulb to this point. I have recently changed the switches to illuminated and the CFL has started to strobe when it is in the off position. I am assuming this is caused by the illuminated switches running in series with the CFL.
Is this correct? Is there any way of using the illuminated switches with a CFL and not getting the flickering or how would you solve it?
Broth is offline   Reply With Quote
Old 11-29-2009, 01:02 PM   #18
My garage light is wired to run off 3 switches. It has operated properly with a CFL bulb to this point. Recently I have changed the switches to illuminated and the CFL has started to strobe when the switches are in the off position. I am assuming this is because the illuminated switch lights are run in series with the CFL.
Is this correct? How do I fix this?
Old 11-29-2009, 04:01 PM   #19
joed's Avatar
Rewards Points: 12,924
There not really any fix for this. If there are more than one bulb then using one non CFL might stop the flickering.
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
Voltage Drop between switch and fixtures CaptMike Electrical 1 06-24-2005 09:30 PM
