3-way Illuminated Switch Help - Electrical - DIY Chatroom Home Improvement Forum
Old 03-11-2011, 01:58 PM   #1
3-way illuminated switch help
Having trouble with an illuminated switch. Main(1) switch(not illuminated) with HOT turns on and off the lights, but other switch(2) does not illuminate when 1 is off, or turn lights on. If switch 1 is on, switch 2 will turn off lights and illuminate, and turn lights on. Checked connections and voltages many times, all are correct. Any help please? Drew a quick diagram of the wiring. Black dots are the common (hot).
DIY-Kennesaw is offline   Reply With Quote
Old 03-11-2011, 02:56 PM   #2
joed's Avatar
Rewards Points: 13,728
The black wires in the drawing needs to be connected to the COMMON terminal on the switch. The position varies by manufacturer so you need to verify this. The common screw is normally black coloured or marked on the switch as COMMON.
Old 03-11-2011, 03:49 PM   #3
Rewards Points: 1,548
Switch 1 might be defective.
Regarding the cable going between the switches ...
Does the red wire to ground show 120 volts with switch 1 in one position and the white wire to ground show 120 volts with switch 1 in the other position?
Do these measurements at both switches.
Old 03-12-2011, 08:21 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
Your symptoms describe incorrect wiring at the switches. If switch 1 has to be in a certain position before switch 2 will work, it's a wiring issue, usually at the switch(es). Your diagram is correct about the way it should be wired, at least to get the 3-way working.
Kyle
Old 03-12-2011, 09:56 AM   #5
Fixed
Thanks for the help, looks like the one marked common on switch 1 was not the common. Switched the common and a traveler and everything started working perfect.
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
3-way switch help amit Electrical 17 02-15-2010 03:17 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
