3 Way Illuminated Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-18-2010, 08:50 AM   #1
3 way illuminated switch
I just want to replace two 3 way switches with illuminated ones.There were 3 wires connected to the old switch (red,white and a black). I changed from the old switch to the new ones and now my light works but the switch doesn't light up when the light is off. I put the black to common and the red and white wire I tried changing on the other terminal screws. Is there suppose to be a green ground?
Bear1309 is offline   Reply With Quote
Old 12-18-2010, 11:05 AM   #2
Electrical Contractor
kbsparky's Avatar
Those switches won't work very well unless you are controlling a significant load, such as an incandescent bulb. What type of bulb are you switching?
-KB
Old 12-18-2010, 12:29 PM   #3
I am using a 40 or 60 watt incandescent bulb.
Old 12-18-2010, 02:04 PM   #4
kbsparky's Avatar
Try using only one of the new switches. The problem could be the extra resistance of using both swiches in series.
-KB
Old 12-18-2010, 05:52 PM   #5
Rewards Points: 81
Some switches require a neutral in the box for illumination.
Chevyman30571 is offline   Reply With Quote
Old 12-21-2010, 06:37 PM   #6
I don't understand what you mean by neutral? Please explain
Old 12-22-2010, 12:59 AM   #7
" Euro " electrician
frenchelectrican's Avatar
What model number that switch you have there ??
Due some of the lighted switch handle some are designed to come on with the load is on { that type set up will required netural }
Some are designed to have the toggle or rocker handle light up when the luminaire is off { this set up do not need netural at all and NOT with CFL or LED bulbs }
so once you posted the model numbers one of us will tell you the straight answer on this one.
Merci.
Marc
Old 12-22-2010, 05:45 AM   #8
Not sure where to find the model number but it is a Decora light switch made by Leviton.
Old 12-22-2010, 09:01 AM   #9
The neutral is, in terms that I understand, the grounded conductor. It is typically (if code compliant) encased in white insulation (in the US, at least).
I would look either at the user manual, or the back of the device, itself. Alternatively, a physical description of the wires coming from your new switches might also be useful.
It sounds like a real possibility that you have your commons and travelers mixed up. Do you remember which wire went to the black screw of your old switch?
oberkc is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
3-way switch help amit Electrical 17 02-15-2010 03:17 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
