3 Way Fan/Light Control - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2008, 01:30 PM   #1
I am attempting to control a fan with a light from both a wall mounted fan/light dimmer switch AND the hand held remote that comes with the fan. It would seem that using the same principle of a 3-way light switch, it would be possible to accomplish.
The fan comes with a remote that has a dimmer for the light and a 3 speed fan control. There is a receiver in the fan canopy.
If I connect both the wall switch and the receiver in the canopy, the light is erratic when using the wall switch. If I turn off the light from the hand held remote, I can no longer turn the light on from the wall switch.
Is there a way to wire this so that it works just like a 3-way where I can turn the light or fan on or off from either the wall switches or the remote?
LaMarguerite is offline   Reply With Quote
Old 03-08-2008, 01:43 PM   #2
The wall switch connects/disconnects the wire going to the ceiling box.
Turn off the switch and you have no power up there.
You are "stuck" with the remote.
edit: You could buy another remote and mount it to the wall by the switch.
220/221 is offline   Reply With Quote
Using a thermostat/relay to control baseboard heater perpetual98 Electrical 10 06-07-2009 11:57 PM
any ideas on how to find washer/dryer control templates for old models? joeyboy Appliances 4 04-05-2008 12:49 PM
control 4 switches gooch Electrical 3 01-03-2008 08:05 PM
