3-way With Extra Lights On Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 07-12-2012, 05:46 PM   #1
Rewards Points: 89
3-way with extra lights on circuit
I know 3-way questions happen quite a bit on here, and I browsed through and didn't find an answer to this one (sorry if I missed it).
We're re-working our kitchen, and one of the circuits will have a fixture with 3-way control as well as 2 other lights on separate switches. Here's the order:
Power from panel --> 1st 3-way switch --> Light Fixture --> 2nd 3-way switch and 2 other switches for other fixtures
I'm getting stuck on what connections to make at the box with the 2nd 3-way and the 2 other switches. Do I need to pull one more wire?
dvaupel is offline   Reply With Quote
Old 07-12-2012, 05:48 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You need to have a wire at the second switch box that will feed the two other switches.
Old 07-12-2012, 05:54 PM   #3
Rewards Points: 89
Do you mean connecting the hot to a jumper?
Old 07-12-2012, 05:54 PM   #4
Master Electrician
yup in your current configuration the 3 way with the feed will also kill the power to the 2 single switches, If you can take your feed to the other box then your fine.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-12-2012, 05:59 PM   #5
E2 Electrician
No, because you won't have a neutral for the two other loads. Excuse my earlier typo, i meant CABLE not wire... sorry.
Old 07-12-2012, 06:20 PM   #6
Rewards Points: 89
Alright...trying to sort out who was replying to what. Am I correct in understanding that I need to feed a fourth wire from the 1st 3-way switch box through to the box with the 2nd 3-way and the other 2 switches? Then use that 4th wire to feed the other 2 switches/fixtures?
Old 07-12-2012, 06:24 PM   #7
E2 Electrician
Andrew was confirming that you need another cable from the first 3 way box to the 2nd 3 way box, as was I...
Old 07-12-2012, 06:24 PM   #8
MarginallyQualified
Rewards Points: 2,464
(2wire cable) --> 1st 3Way <-- (3wire cable) --> 2nd 3Way --> (2wire cable) -->Light --> Light --> light
Old 07-12-2012, 06:25 PM   #9
E2 Electrician
You forgot the two other single pole switches.
Old 07-12-2012, 06:47 PM   #10
Master Electrician
here's my super easy to read paint diagram
edit: i forgot the grounds from the two wires to the lights
Old 07-12-2012, 08:18 PM   #11
Rewards Points: 89
Thanks for the drawing, but a correction....the extra switches are not in the box with the 2 wire feed....they're on the other end. And the light is in between the 3-way switches, not after the 2nd one.
Maybe I'm overthinking it, but it seems like something extra is needed since the switches are on the other end of the run.
Old 07-12-2012, 08:25 PM   #12
E2 Electrician
And you are correct, run a separate feed to the box with the single pole switches...
Old 07-12-2012, 08:36 PM   #13
joed's Avatar
Rewards Points: 13,322
No need for a SEPARATE feed. Just run the one feed to that box and all will be well.
Old 07-12-2012, 08:38 PM   #14
E2 Electrician
I didn't mean it in that sense, just wanted him to grasp the concept that he needed to feed the two switches...
Old 07-12-2012, 09:01 PM   #15
Master Electrician
i know, that's how it should be wired, i wouldn't draw it for you the way you have because there's no way to make that work without adding a two wire romex from box a to box b or change your feed so it's like my amazing to scale picture.
ooops on the light between the 3 ways. You still would need to do the above to make your single pole switches work.
Add Can Lights to a 20 A Circuit BusyPete Electrical 3 01-29-2012 03:31 PM
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Recessed Lights / 15 AMP Circuit ericm215 Electrical 5 06-11-2011 12:41 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
