3 Way Dimmers - Electrical - DIY Chatroom Home Improvement Forum
Old 03-25-2008, 02:54 PM   #1
3 Way Dimmers
This may be a really basic question, but I can't get my mind around it for some reason. If I am using a 3 way dimable switch, do both switches need to be dimmers?
nthomp16 is offline   Reply With Quote
Old 03-25-2008, 03:00 PM   #2
Rewards Points: 2,350
No. Most 3-way dimmers work with a regular 3-way switch at the other end. There are smart dimmers on the market which allow for both sides to be dimmers, but this probably isn't the case in your setup.
InPhase277
Old 03-25-2008, 04:23 PM   #3
I guess I have just been over-thinking the whole thing. I assume you would want the dimmer on the first switch...but then would the second switch just turn the lights on to the level left by the dimmer or would it override the dimmer?
Old 03-25-2008, 04:49 PM   #4
Rewards Points: 504
The dimmer portion of a 3-way dimmer is in line with the common terminal. The switch portion is a regular 3-way switch. When you dim the load, that's it's "on" position and if you dim down to zero, there is no way the other 3-way can turn the light on, because it's choices are off or fully dimmed.
LawnGuyLandSparky is offline   Reply With Quote
Why Not Two 2-Way dimmers ? Piney Electrical 14 12-31-2008 05:33 PM
Two 3-way Dimmers? jelly Electrical 4 11-24-2007 09:36 AM
12V dimmers? smallcrpt Electrical 2 03-23-2007 06:29 AM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
