3-Way Dimmer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2009, 10:04 AM   #1
3-Way dimmer switch
Trying to figure out how to hook up a 3-way dimmer light system to 4 potlights. I have power coming into the first switch. Any help would be great.
stonehaven is offline   Reply With Quote
Old 09-21-2009, 10:09 AM   #2
Licensed electrician
Rewards Points: 1,240
Are you just replacing an existing 3w toggle or do you need to still run the wiring for the switches and lights?
Old 09-21-2009, 10:14 AM   #3
I need to run wire for the switches and lights.
Old 09-21-2009, 11:43 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
From the first switch, run a 3 wire cable to the second switch.
From the second switch, run a 2 wire cable to the first light, then to each light.
At the first switch, connect the white wires together, and the hot wire to the common termnial or wire on the dimmer.
At the second switch, connect the whites together, and the black wire going to the light connect to the common screw on the switch.
At both switchs, connect the black and red wires to the remaining screws and turn the power on.
Old 09-21-2009, 01:12 PM   #5
Thanks jbfan
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 10:08 AM
Dimmer Switch Vandiyan Electrical 21 12-15-2008 08:23 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 11:57 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
