Old 03-29-2008, 09:07 PM   #1
3 way dimmer help
I just installed a dimmer switch into my dining room. The room has 2 switches. The first switch I replaced with the dimmer. The second switch is a regular toggle flip switch. It seems that only one switch can control the lights. One switch can turn on and off the lights, while the other won't be able to turn on the lights. Is there something wrong with the current of the poles? What else could be wrong?
townpump is offline   Reply With Quote
Old 03-29-2008, 09:36 PM   #2
Electrician
3 way dimmer help
You messed up the travelers on the 3 way you installed.
chris75 is offline   Reply With Quote
Old 03-29-2008, 09:59 PM   #3
3 way dimmer help
I have tried to rearrange it numerous ways.
Any other possibilities.
Old 03-29-2008, 10:00 PM   #4
3 way dimmer help
Did you take the initiative to mark the power and travelers before removing the original switches.
JGarth is offline   Reply With Quote
Old 03-29-2008, 10:14 PM   #5
Floor Sweeper
3 way dimmer help
Does it work correctly if you reinstall the old switch?
Are you using a three way dimmer? (not a single pole one..)
junkcollector is offline   Reply With Quote
Old 03-29-2008, 10:28 PM   #6
Union Electrician
goose134's Avatar
3 way dimmer help
Your new dimmer should have three wires and a ground.
A single pole will have two wires and a ground.
goose134 is offline   Reply With Quote
Old 03-29-2008, 10:35 PM   #7
3 way dimmer help
The 3 way dimmer is a multi-pole. It has 4 wires. I unfortunately didn't write down what wires were what. When I replace the old switches, they don't work properly.
Old 03-29-2008, 10:42 PM   #8
Electrician
3 way dimmer help
Looks like you better call someone more qualified...
Old 03-29-2008, 11:55 PM   #9
" Euro " electrician
frenchelectrican's Avatar
3 way dimmer help
what kind of dimmer you have ??
maybe one of us can help ya
some 3 way dimmer do have master and slave units they are little tricky to get wired right
Merci,Marc
Old 03-30-2008, 12:31 PM   #10
Licensed Electrician
jrclen's Avatar
3 way dimmer help
Try to give us more information. Like Marc said, we will try to help you. Look at these diagrams for an idea of how three way switches are wired.
http://www.thecircuitdetective.com/3...htm#threebasic
If you are not comfortable with any of this, please call an electrician. No sense getting hurt just to save some money.
jrclen is offline   Reply With Quote
Changing A Dimmer badgerbrian1974 Electrical 8 02-17-2008 10:15 PM
dimmer switch circuit wiring stan_d_bballman Electrical 2 11-17-2007 12:44 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
OK to user a dimmer with ceiling light? FreeCashBack.co.uk Electrical 2 06-19-2005 10:16 PM
