-   -   3 way dimmer help (http://www.diychatroom.com/f18/3-way-dimmer-help-19203/)
townpump 03-29-2008 08:07 PM
3 way dimmer help
I just installed a dimmer switch into my dining room. The room has 2 switches. The first switch I replaced with the dimmer. The second switch is a regular toggle flip switch. It seems that only one switch can control the lights. One switch can turn on and off the lights, while the other won't be able to turn on the lights. Is there something wrong with the current of the poles? What else could be wrong?
chris75 03-29-2008 08:36 PM
You messed up the travelers on the 3 way you installed.
townpump 03-29-2008 08:59 PM
I have tried to rearrange it numerous ways.
Any other possibilities.
JGarth 03-29-2008 09:00 PM
Did you take the initiative to mark the power and travelers before removing the original switches.
junkcollector 03-29-2008 09:14 PM
Does it work correctly if you reinstall the old switch?
Are you using a three way dimmer? (not a single pole one..)
:thumbsup:
goose134 03-29-2008 09:28 PM
Your new dimmer should have three wires and a ground.
A single pole will have two wires and a ground.
townpump 03-29-2008 09:35 PM
The 3 way dimmer is a multi-pole. It has 4 wires. I unfortunately didn't write down what wires were what. When I replace the old switches, they don't work properly.
chris75 03-29-2008 09:42 PM
Looks like you better call someone more qualified... :laughing:
frenchelectrican 03-29-2008 10:55 PM
what kind of dimmer you have ??
maybe one of us can help ya
some 3 way dimmer do have master and slave units they are little tricky to get wired right
Merci,Marc
jrclen 03-30-2008 11:31 AM
Try to give us more information. Like Marc said, we will try to help you. Look at these diagrams for an idea of how three way switches are wired.
http://www.thecircuitdetective.com/3...htm#threebasic
If you are not comfortable with any of this, please call an electrician. No sense getting hurt just to save some money.
