3 Way Dimmer? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-06-2006, 02:42 PM   #1
3 way dimmer?
i am renovationg my living room/dining room area. i was driving home today thinking how nice it would be to have my lights on dimmers. i am going to do 3 way switches though. can you get 3 way dimmers? i want to be bale to control my lights from opposite walls which are 25' apart. anything special required for them? or can i just go ahead and wire for 3 way switches and if i want, install dimmers as an upgrade?
jamesdart is offline   Reply With Quote
Old 09-06-2006, 02:51 PM   #2
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
You have two options -
1. Get a 3-way dimmer and a 3-way switch. Wire them as you would normally wire 3-way switches. You will be able to dim from one but only control off and on from the other.
2. Get a specially designed set of dimmers which are designed to dim from mulitple location. These are called multiple location dimmes, like the Maestro from Lutron. These prove to be quite expensive, like $50+ ea. Personally, I have never found the strong desire to dim from each location. I have always been happy with a simple $10-15 dimmer and a regular 3-way switch - as opposed to $100 for two ML dimmers. I find that dimming is a special situation which would not cause great inconvinience to walk across a room when desired. The 2nd switch in a 3 way circuit is usual useful for turning a light off when leaving a room, or providing some light for visibility when entering from that particular side - in either case a simple rocker or toggle does just fine. I have not personally used the ML dimmers, but have heard from the only person that I know that ponied up for them, that they "annoyed" him.
J187 is offline   Reply With Quote
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Dimmer with Florescent TonyD Electrical 1 06-08-2007 02:26 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
Heat from new dimmer?!?! davo420 Electrical 4 02-23-2006 04:17 PM
OK to user a dimmer with ceiling light? FreeCashBack.co.uk Electrical 2 06-19-2005 09:16 PM
