3-WAY~Continuing ED - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2014, 11:04 PM   #1
Rewards Points: 512
3-WAY~Continuing ED
Just trying to further my understanding.
Would PIC 2 work the same as PIC 1?
EDIT See post 3 for corrected pic
Installation is the Reverse of Removal.
Old 02-05-2014, 11:06 PM   #2
Rewards Points: 512
Nevermind i got it wrong
Old 02-05-2014, 11:12 PM   #3
Rewards Points: 512
Here's corrected version
Old 02-06-2014, 12:42 AM   #4
Licensed electrician
Rewards Points: 1,440
Those are not between the switches. That shows a dead end three way.
sirsparksalot (02-06-2014)
Old 02-06-2014, 01:01 AM   #5
Rewards Points: 512
A "dead end three way"? Are you referring to my wiring, or the original?
Will my wiring work?
To keep things simple, for me, I always try to find ways to run 3-wire between switches without going through the lighting fixture.
Old 02-06-2014, 07:44 AM   #6
joed's Avatar
Rewards Points: 12,322
The new drawing will work. However it does not meet the new code requirement for neutral conductor at the switch.
The Following User Says Thank You to joed For This Useful Post:
Old 02-06-2014, 09:08 AM   #7
Rewards Points: 512
Thanks guys,
Would still like to know what the term "dead end three-way" means.
Old 02-06-2014, 01:06 PM   #8
joed's Avatar
The drawing in post#3 is a dead end three way. One of the three way switches is at the end of the cable, a dead end.
Old 02-06-2014, 02:25 PM   #9
The first diagram doesn't result in a neutral conductor into the second switch box either. How would you wire either of these arrangements to get a neutral in both switch boxes?
northernlite is offline   Reply With Quote
Old 02-06-2014, 02:46 PM   #10
Rewards Points: 512
Did you not see this: EDIT See post 3 for corrected pic which I posted in #1?
Old 02-06-2014, 02:50 PM   #11
joed's Avatar
You would need to use a four wire cable with a white or choose a different wiring method that would result in the neutral passing through the switch box. One example would be to connect the light to the second switch instead of the first one.
northernlite (02-06-2014)
Old 02-06-2014, 02:53 PM   #12
I did. Guess I'm missing or misunderstanding something though, or I'm just dense. I don't see a neutral at the second box.
Old 02-06-2014, 02:56 PM   #13
Thanks joed. got it.
I set up my whole wiring plans to bring power into the switches as per the diagram shown. damn. o well it's all still open. adapt and overcome.
I know it's not code in Canada (yet) to need neutrals in each box but might as well try...
Old 02-06-2014, 03:16 PM   #14
Rewards Points: 512
I'm sorry, I thought you were referring to the typo in my 1st post, but you were asking about neutrals being in both switches. I apologize.
The Following User Says Thank You to sirsparksalot For This Useful Post:
