3 Way CFL Blinking - Electrical - DIY Chatroom Home Improvement Forum
Old 09-14-2012, 07:17 PM   #1
3 Way CFL Blinking
I recently replaced 2 old 3 way switches in my home with new 3-Way lighted ones. All connections appear to be the same. Lights turn ON/OFF properly, but while OFF, the light faintly blinks. I've tried 2 diff bulbs (CFL) with the same result. I also placed the old switch back on one and the blinking stopped.
I'm sure this is a stupid question, but I found no results in searching these forums. Thanks for any assist!
e-noob is offline   Reply With Quote
Old 09-14-2012, 07:40 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
It has to do with the CFL's and the illuminated switches, lose one or the other.
Old 09-14-2012, 07:42 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,096
Probably a small phantom current is present in the lines,
Not enough to fully light it,
But enough for a faint burst every now and then.
dmxtothemax is offline   Reply With Quote
Old 09-14-2012, 07:46 PM   #4
E2 Electrician
Its not phantom at all, the illuminated switch is in series with the lamp at the light fixture, the switch draws such little current it wont light a normal lamp, but it will raise hell with a CFL....
Old 09-14-2012, 11:15 PM   #5
It sure would !
Tags
3 way switches , blinking
New T5 Ballast causing Blinking gray0239 Electrical 3 01-05-2012 12:37 AM
comfort aire furnace-led light blinking raiderfan HVAC 2 01-14-2011 11:12 AM
DUCANE HEATER, led blinking red 3 times tom356 HVAC 1 09-04-2010 06:47 PM
Outdoor post light - random blinking bulb handymike Electrical 9 06-14-2010 02:29 PM
Amana roll out switch light blinking butter99 HVAC 2 04-02-2010 11:19 PM
