3-Way To 2-Way - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2008, 04:04 PM   #1
Video Guy
SillyGoose's Avatar
Question
3-Way to 2-Way
Tricky situation for me because I am not too familiar with the 3-way switch. Basically, there was a 3-way switch in my guest bedroom that controlled two different plug outlets. I have installed some can lights in the room and what I want to do is make the plug on all the time and now have the lights operating from the switch, but not make it a 3-way switch, I want it to be a regular, single pole switch. Which wires do I need to nut together to get the plugs to always be on?
SillyGoose is offline   Reply With Quote
Old 07-14-2008, 04:09 PM   #2
How many wires, and what colors are in the switch box?
FW
fw2007 is offline   Reply With Quote
Old 07-14-2008, 04:18 PM   #3
Video Guy
SillyGoose's Avatar
I will have to post some pictures of it. Its more complicated than I once though.
Old 07-14-2008, 04:38 PM   #4
joed's Avatar
Rewards Points: 12,892
You will need to open both switches and tell us all the wires in both switch boxes and the receptacles. Also which switch is the new cable for the pot lights going into?
Old 07-14-2008, 08:06 PM   #5
Video Guy
SillyGoose's Avatar
Question
OK, here are the pictures with all the wires labeled. I do not know why but there are some instances where the white wire is nutted in with the ground. I am no electrician but that doesn't seem right. Anyways, here are the pictures; The primary shot is where the new switch will be put in along with all the previous wiring. The secondary shows what was plugged into the other switch. I want to get rid of the secondary all together but it if you all remember, it is used to control some plugs so I have to nut some wires together so those plugs still work. Thanks in advance for the help guys!
Old 07-14-2008, 10:14 PM   #6
joed's Avatar
Three way switches have three wire connected to them. I only see two that look like they were on the switch. Neutrals and grounds connected together is absolutley wrong and needs to be corrected. You have some major issues that need to be addressed.
Old 07-15-2008, 09:46 AM   #7
Video Guy
SillyGoose's Avatar
I am really starting to hate the electricians who did my house back in 1976.
