3 Wall Outlets Read "open Ground" - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2009, 06:21 PM   #1
3 wall outlets read "open ground"
I replaced all the wall outlets in my house and checked all the outlets with a circuit tester. They all showed fine except for 3 of them (in bedroom and bathroom). What do I need to do to make it not read "open ground" and to make it correct?
proofer is offline   Reply With Quote
Old 06-04-2009, 06:39 PM   #2
300zx's Avatar
Post
Go back to the closest outlet that has a ground and pull out and check the ground wires maybe the wire broke off or something, Check that they are twisted together good and have a green wire nut or pigtail or copper crimp to ensure they have good connection.
300zx is offline   Reply With Quote
Old 06-04-2009, 07:23 PM   #3
Rewards Points: 156
ground
Pigtail the grounds to the ground screw on the outlets.
jayp is offline   Reply With Quote
Old 06-04-2009, 07:27 PM   #4
Yes, I've checked that and they're all pigtailed to the ground properly.
Old 06-04-2009, 07:29 PM   #5
Yes, I've checked that and they all have a good connection.
Any other ideas?
Old 06-04-2009, 07:38 PM   #6
Rewards Points: 334
Did they test OK before ?
tribe_fan is offline   Reply With Quote
Old 06-04-2009, 07:57 PM   #7
They had never been tested before.
Old 06-04-2009, 09:12 PM   #8
Bigplanz's Avatar
Rewards Points: 948
It is possible they were never grounded. How old is the house? If there is no ground, install a GFCI. At least then there will be some protection from ground faults. One GFCI (the first in series) if they are all on the same circuit. Three individual GFCIs otherwise.
Bigplanz is offline   Reply With Quote
Old 06-06-2009, 01:02 PM   #9
It could be possible that they were never grounded. This particular part of the house was added on in 1980. We'll look into it further and if we can't figure it out, we'll go with that GFCI approach. Thanks.
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 11:24 PM
Half-height Cinder Block wall Electrical theatretch85 Electrical 11 04-09-2009 12:49 AM
Outlets on both sides of wall? and height question DIYGST Electrical 10 02-08-2009 07:11 PM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 01:24 PM
