Old 04-17-2012, 10:56 PM   #1
3 switches, one plate, top one not working
I have a switch plate in the bathroom that has worked just fine for 6 years, now the top switch which is the light switch, wont "click" into the on position. It just springs back to the off position. The other two are to the ceiling exhaust fan, and the heater in the same unit as the fan.
The heater switch sparks now, it did not before. What can I do?
Thanks, Ellie
ellie1955 is offline   Reply With Quote
Old 04-17-2012, 11:02 PM   #2
Licensed Electrician
k_buz's Avatar
Replace the switch, sounds like something internally went bad.
The Following User Says Thank You to k_buz For This Useful Post:
ellie1955 (04-17-2012)
Light switches stopped working HALLJ12 Electrical 2 11-06-2011 03:50 AM
Question about switches on a 20 amp circuit Abs777 Electrical 6 04-28-2010 11:09 AM
Help me ID these switches... jp2code Electrical 10 12-11-2009 03:15 PM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 07:19 PM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 09:33 PM
