#16 |
3 switches in a 4-gang box?
Why? In drywall the box can be 6mm behind, so if I put mesh tape over the 4th opening and used compound it would still be 6mm behind. And I'm not burying the box as the other 3 openings would still be there.
#17 | |
Electrician
3 switches in a 4-gang box?Quote:
IMO, the method you are suggesting is not an approved method. You have a 4 gang box, you need to cover that box with a 4 gang cover that has been approved for the purpose. IMO, a three gang cover combined with some mud and tape is not approved for this purpose (not to mention it is hack workmanship). The inspectors in my area would agree. Maybe the inspectors in your (or the OP's) area would allow your method, I don't know. |
#18 |
Install a dummy switch and move on.
It may drive the next homeowner nuts but.....oh well
#19 |
You talking to me?
hook the switch to a large loud buzzer or other noise make and put a little label on below the switch that says:
do not touch!! gets 'em every time. They just can't resist. |
#20 |
Fair enough, but I don't see how the code section you quoted prevents what I said; even pulled out my handbook to see if there were notes to that effect, there aren't. Not disagreeing that it's a hack, and probably wouldn't pass inspection, just trying to understand why.
#21 | |
You talking to me?
the section cited may be stretched a bit to not allow filling a box with mud as the amount of exposed mud (or other non-flammable materials) must be less than 1/4 inch. If you fill a section of a box, you would have more than 1/4 inch exposure. |
#22 |
What I'm proposing isn't filling the empty space w/mud, but rather "patching" the space on the wall over the box as if it was a hole in the wall. The box itself would remain open behind the patch (and would be accessible through the other switches). At any rate, I agree, a hack. It must be like ****, we know it when we see it, even if we can't define it. :-)
#23 |
Wounded Mathematician
Since I have way more important things to do, I'm just gonna put a dummy switch there. I spoke to the inspector and he said that's ok. He said that from a safety perspective, the only other approved way would be to replace the box.
I did ask about taping/mudding over just that part of the box, but he said no. It does seem like a hack anyway. I may yet come up with a use for that switch someday anyway - possibly a 3-way switch to an outdoor light on a yet-to-be-built shed in the back yard.
The poets have been mysteriously silent on the subject of cheese. G.K. Chesterton
#24 | |
You talking to me?
There is no way to prevent it unless you put some sort of blank over the opening and then it would probably be illegal since you cannot cover a cover. |
#25 | |
The purpose of a jbox is to contain fire. If a portion of it is left open to the drywall paper/patch it will likely burn thru faster than it's two hour rating. |
| Display Modes | |
| Replacing switches turning into nightmare. | RyanD | Electrical | 19 | 05-26-2009 07:19 PM |
| Need help replacing switches in four-way circuit | magnolia | Electrical | 3 | 05-09-2008 10:40 PM |
| grounding switches in old work plastic two gang box | wkend2 | Electrical | 3 | 03-05-2008 01:33 PM |
| 2 gang box to 4 gang box | jwn2126 | Electrical | 2 | 03-20-2006 11:03 AM |
| wiring switches in 3 gang box | bobo | Electrical | 2 | 02-20-2006 11:13 AM |
