3 Switches In A 4-gang Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2009, 02:44 PM   #1
Wounded Mathematician
shtoink's Avatar
3 switches in a 4-gang box?
Hi
I have a 4-gang box in my kitchen which holds 4 light switches, but now I only need 3 of those switches. I have completely disconnected the wiring for one of those switches, and it looks like it will be pain in the arfe to rip out the 4-gang box, replace it with a 3-gang box and patch the wall on one side.
Of the following options, what would you recommend?
1. Keeping the 4-gang switch box as is but with one switch that isn't connected to anything.
2. Putting on a 4-gang sized switch cover plate that only has 3 switch openings and one covered. Do they even make such a thing? Could I make such a thing by somehow covering one of the holes?
3. Bite the bullet and replace it with a 3-gang box.
The poets have been mysteriously silent on the subject of cheese.
G.K. Chesterton
shtoink is offline   Reply With Quote
Old 10-13-2009, 02:50 PM   #2
47_47's Avatar
Rewards Points: 44
If I was doing a remodel in the kitchen, replace the box. If just working on the lighting circuits, leave in a switch that does nothing. Just my 2
47_47 is offline   Reply With Quote
Old 10-13-2009, 03:48 PM   #3
Rewards Points: 346
You can buy switch blank fillers for less than a buck and it saves having to explain what that switch does....
RegeSullivan is offline   Reply With Quote
Old 10-13-2009, 04:22 PM   #4
WaldenL's Avatar
Rewards Points: 268
Leave the switch or, if you can you cut out the 4-gang box, replace it w/a 3 gang old work and use mesh and drywall compound to fill in the hole.
Or I've heard you can use mesh and compound to cover the opening in the 4 gang box, and add a 3-gang switch cover, not that I'd recommend such a thing. Actually, what's the code say about doing that? The box is still accessible. Is that a code violation? If so, why?
WaldenL is offline   Reply With Quote
Old 10-13-2009, 04:34 PM   #5
Rewards Points: 160
Either HD or Lowe's sells individual cover plates that you can combine in absolutely any combination - blank, switch, regular receptacle, GFI receptacle. They have interlocking tabs except for one side of the ones designed to go at the end. But they are IMO ridiculously expensive -- like a buck or more each. Before I found those I just made a careful cut across each of two stock plates - an angle grinder gave me a very straight cut -- can barely see the joint. It's probably not up to code in the sense that the cover plates aren't "listed" for that kind of modification. So forking over the $ to the store is probably the way to go.
Or just leave a switch that does nothing.
philS is offline   Reply With Quote
Old 10-13-2009, 05:21 PM   #6
Rewards Points: 160
shtoink - ignore my previous message - my brain was out of gear. Just go buy a 3 gang mud ring for a 4 gang box. If your big box store doesn;t have one, any electrical supply store will. They'll stock everything from one gang to four gang mudrings for a four gang box. Cut back your sheet rock just enough to mount the mud ring, then patch around it with mesh tape and tape mud. It'll look nice and is code compliant.
Old 10-13-2009, 05:34 PM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Leave the switch. It will baffle people about what it does.
jbfan is online now   Reply With Quote
Old 10-13-2009, 06:39 PM   #8
shtoink's Avatar
Since I have many way more important projects to finish, I'll probably just leave it as a disconnected "mystery switch".
Another ridiculous idea I just had is to wire it as a 3-way switch with the switch right next to it - the world's most pointless 3-way light switch.
G.K. Chesterton
Old 10-13-2009, 06:40 PM   #9
WaldenL's Avatar
Rewards Points: 268
That gets my vote!
Old 10-13-2009, 06:44 PM   #10
shtoink's Avatar
Originally Posted by WaldenL View Post
That gets my vote!
I would only need a tiny scrap of 3-wire cable to do it too.
G.K. Chesterton
Old 10-13-2009, 06:56 PM   #11
Residential Contractor
Better make it a 5 gang box and add a 4-way for the same bank.
rselectric1 is offline   Reply With Quote
Old 10-13-2009, 08:23 PM   #12
WaldenL's Avatar
Rewards Points: 268
Or wire them in series, and put one upside down. It will be like a combination to turn on the light. up-down-up, or up-up-down, or down-up-down... And then flip the switches every month just to annoy the family.
Old 10-13-2009, 08:32 PM   #13
You're bad walden
Old 10-13-2009, 09:44 PM   #14
Rewards Points: 1,442
I vote for putting a non-functioning switch in the fourth position. I would not go the route of an adapter mud ring because I don[t want to do the work of cutting and mudding around it.
AllanJ is online now   Reply With Quote
Old 10-13-2009, 09:49 PM   #15
Electrician
Just one section of code that comes to mind
Originally Posted by NEC 2008
314.20
In Wall or Ceiling. In walls or ceilings with a surface
of concrete, tile, gypsum, plaster, or other noncombus-
tible material, boxes employing a flush-type cover or faceplate
shall be installed so that the front edge of the box, plaster ring,
extension ring, or listed extender will not be set back of the
finished surface more than 6 mm (V4 in.).
In walls and ceilings constructed of wood or other combustible
surface material, boxes, plaster rings, extension
rings, or listed extenders shall be flush with the finished
surface or project therefrom.
Having a portion of the box covered with plaster/drywall would violate this code.
EBFD6 is offline   Reply With Quote
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 07:19 PM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 10:40 PM
grounding switches in old work plastic two gang box wkend2 Electrical 3 03-05-2008 01:33 PM
2 gang box to 4 gang box jwn2126 Electrical 2 03-20-2006 11:03 AM
wiring switches in 3 gang box bobo Electrical 2 02-20-2006 11:13 AM
