3 Switches, 1 Power Feed, 2 Boxes - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 07:42 PM   #1
3 switches, 1 power feed, 2 boxes
I have 3 lighting banks on 3 switches, fed from 1 circuit. light bank #1 consists of 2 pot lights, #2 a ceiling fan, and #3 3 pot lights. I don't need them to be 3 or 4 way switched. but I am stumped on how to feed them to make them work.
stumped586 is offline   Reply With Quote
Old 07-26-2011, 07:47 PM   #2
I=E/R
a7ecorsair's Avatar
So what are you trying to do? Your posting doesn't give us much to work with. Are you wiring new circuits or are you redoing old circuits. Why did you mention 3 and 4 way switches?
a7ecorsair is offline   Reply With Quote
Old 07-26-2011, 07:50 PM   #3
I have gutted my cottage and rewired it to bring it up to code. all walls are open and all power and lighting circuits and breakers are new. I mentioned 3 and 4 way switching because the location of the lights looks like that might be logical but I just want each bank switched separately but from 1 circuit but all 3 are independent. Does that help? thanks for replying to my post.
Old 07-26-2011, 07:58 PM   #4
I=E/R
a7ecorsair's Avatar
Helps a lot
Do you want the three switches together in a three gang box?
Old 07-26-2011, 08:01 PM   #5
I have bank #1 with the 2 pot lights and bank 2 with the ceiling fan in 1-2 gang box and across the room I have the switch for the 3 pot lights. power feed comes into box 1 with the 2 switches and then out to the box across the room.
Old 07-26-2011, 08:09 PM   #6
I=E/R
a7ecorsair's Avatar
Switch box #2 - You should have a cable coming from the lite to the switch. Connect the two whites together and connect one black to each switch screw.
Switch box #1 - connect the whites together like above and connect the black from each light to a screw on each switch. For power you will have add two pigtails to the black power feed and then connect one to each switch.
Old 07-26-2011, 08:14 PM   #7
I think its more complicated than that. Box 1 has 4 cables, 1- power in, 1 power out to box 2, lights in and fan in. box 2 has power in from box 1 and lights in. So I have lots of neutrals, grounds and hots in box 1.
Old 07-26-2011, 08:19 PM   #8
I=E/R
a7ecorsair's Avatar
My description covers what you are telling me. In box 1 you will have four white wires under one wire nut, four blacks under a wire nut (two wires and two pigtails).
Old 07-26-2011, 08:20 PM   #9
thank you then. I will give it a try. Tanks again.
Old 07-26-2011, 08:22 PM   #10
I=E/R
a7ecorsair's Avatar
What size wire are you using?
Old 07-26-2011, 08:37 PM   #11
12/2-all 20 amp circuits
Old 07-26-2011, 08:40 PM   #12
I=E/R
a7ecorsair's Avatar
If this will be inspected you may have problems with box fill.
Old 07-26-2011, 08:41 PM   #13
i do have a permit for this and it will be inspected. and yes the box is very full
Old 07-26-2011, 08:43 PM   #14
I=E/R
a7ecorsair's Avatar
Do you know how to calculate box fill?
Old 07-26-2011, 08:44 PM   #15
not a clue. I am a diy'er. above average skills but still not a pro
Boxes recessed too deep rondo Electrical 10 12-01-2012 06:46 PM
Help with Two Switches & Two Lights simplyphp Electrical 36 11-25-2010 02:47 PM
power to "half" the house dogvila Electrical 8 07-13-2010 09:04 PM
Add more power to the house? (kinda long) tmtrebor Electrical 5 04-30-2010 03:19 PM
power panel missing, all receptacles & switches removed shortsell Electrical 2 03-24-2010 10:12 AM
