3 Sets Of Wires Going To Porch Light - Electrical - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 03:27 AM   #1
Angry
3 sets of wires going to porch light
yeah im trying to instal back porch light on mobile home but when i took the old one down there was 3 sets of wires ive figured out what they are now just need help hooking them up
cowboy618 is offline   Reply With Quote
Old 06-19-2012, 05:38 AM   #2
Rewards Points: 1,512
You would hook up a new light in the same way the old light was hooked up.
Old 06-19-2012, 08:08 AM   #3
Rewards Points: 2,516
Do you mean you have 3 cables in the light fixture box? But still do not understand your question. If you have figured out what each cable is for like, power in, switch loop, etc... why are you having an issue hooking up the light?
hammerlane is offline   Reply With Quote
Old 06-19-2012, 10:07 AM   #4
Rewards Points: 1,456
Three sets of power/neutral/ground? Like one was used to splice to a new fixture/outlet? You didn't pay attention to how the old one was wired?
mikegp is offline   Reply With Quote
Old 06-19-2012, 10:33 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I will NEVER understand why people take stuff apart when changing a light fixture or a device. What goes on in the head that makes one think that it is a good thing to do?
Old 06-19-2012, 11:29 AM   #6
ive got everything hooked back up i just need to power my light switch from main power to switch wires cant figure that part out
Old 06-19-2012, 11:30 AM   #7
k_buz's Avatar
Sounds like you don't have it hooked up correctly then.
You probably have a power feed coming to the light, a power feed leaving the light, and a switch loop.
Old 06-19-2012, 11:32 AM   #8
ive got main power wires going to outside plugin on outside trailer than had another set of wires that hooked up from there to my light switch but now i cant figure out where to run light switch wires
Old 06-19-2012, 11:37 AM   #9
the main power wire runs the plugin outside the trailer than it had one coming off the main power wires to the light switch to power the light on and off i need to no how to run light switch wires to main power so it works
Old 06-19-2012, 11:46 AM   #10
What is your recollection of a:
1.main power wire runs
2.plugin
3.main power
Maybe provide a photo
Old 06-19-2012, 11:46 AM   #11
k_buz's Avatar
Are you installing a new switch to this light? Your posts are very had to understand.
Old 06-19-2012, 11:47 AM   #12
This statement makes the most sense out of anything posted here.
Old 06-19-2012, 11:50 AM   #13
k_buz's Avatar
LMAO...oops
...haRd to understand.
Old 06-19-2012, 12:48 PM   #14
well tried to post pic of it but wont let me for some reason
Old 06-19-2012, 12:54 PM   #15
k_buz's Avatar
With the information given...
black from power in--->black from power out--->white (needs to be taped black) from the switch
white from power in--->white from power out--->white from fixture
black from the switch--->black from fixture
trying to figure out Knob & Tube wiring on old light fixture dalethompson Electrical 16 02-02-2012 08:42 PM
Porch light unpowered by separate multi-way switch S_Jeff Electrical 11 12-13-2011 06:24 PM
overhead light fixture has 9 wires? pokey1984 Electrical 8 11-14-2011 08:04 PM
Ceiling Fan installation, 3 sets of wires in ceiling southnam Electrical 3 09-13-2010 03:00 PM
Installing New Porch Light, Electrical Box GeauxCajuns82 Electrical 1 12-19-2008 05:16 PM
