Old 03-10-2008, 04:46 PM   #16
UAW SKILLED TRADES
Stubbie's Avatar
3 prong range?
I actually think we are all on the same page here though a little impatient in getting all the facts. We all know 3 wire existing is allowed if.....
I also agree (after rereading) with the fact this is likely a se but I sure would like that to be verified along with other things like are we going from cooktop to range or range to range. I just haven't dealt with copper ser from that era that I can recall we have almost always came across al seu not copper ser or seu.
Old 03-10-2008, 05:06 PM   #17
3 prong range?
Slide in range is the same as a drop in..........but it slides in
220/221 is offline   Reply With Quote
Old 03-10-2008, 05:06 PM   #18
Licensed Electrical Cont.
Speedy Petey's Avatar
3 prong range?
Oh.
Old 03-10-2008, 05:07 PM   #19
UAW SKILLED TRADES
Stubbie's Avatar
3 prong range?
Not according to the Frigidaire website....
Old 03-10-2008, 05:15 PM   #20
3 prong range?
Don't you guys ever WORK?
Old 03-10-2008, 05:19 PM   #21
3 prong range?
Look who's talking. You posted earlier than me today.
Old 03-10-2008, 05:26 PM   #22
3 prong range?
Hey, I already did my 2 service calls today, cleaned my pool and logged about 50 miles on my truck.
Old 03-10-2008, 05:29 PM   #23
3 prong range?
You sure? A slide in is a range that has an oven and burners. A drop in is a cooktop with burners only. Right? Anyone?
jerryh3 is offline   Reply With Quote
Old 03-10-2008, 05:31 PM   #24
3 prong range?
First, thank you all for your help!
So it is range to range...the freestanding just touches the kitchen floor, whereas a drop-in sits on a toekick....but they perform exactly the same functions.
By highend, I mean a 1k Frigidaire stainless steal convection oven. I should qualify that, as "highend" means different things to different people.
The condo unit has two panels for our unit, one in the basement of the unit and one in the unit itself....does this mean one is a subpanel?
Im not sure rerunning a cable is a possibility, as drywall from three other units would need to be ripped out (not happening) and so on....not a simple fix. Im guessing this is why older 3-prong connections fall under grandfather rules.
The old range somehow worked with the 3 wire connection, but it was a direct wire (as are most dropins) whereas this freestanding needs a 3 or 4 prong connection (as most do). 4 will not work as I only have 3 wires (two hot and the braided copper)...
They come out of the wall together in one rubberlike tube (all in the same tube). I assume that is a SE Cable?
So, I followed the directions on the box of the black three-prong outlet I bought at HD, which said the two hot go in the outer screws and the braided copper goes to the neutral in the center. I then also ran a ground wire connecting that braided copper to the metal back of the outlet (marked in green and 'ground'). I believe this is basically what you all have said is correct as well?
Hopefully....
laduehelp is offline   Reply With Quote
Old 03-10-2008, 05:33 PM   #25
3 prong range?
A cooktop range only has burners.
A drop-in also has an oven.
But this likely depends on manufacturer.
Old 03-10-2008, 05:38 PM   #26
UAW SKILLED TRADES
Stubbie's Avatar
3 prong range?
I'm retired.........
Hey... the point is that none of us are wrong. My opinion at this point is that the cable is likely an se cable . Though if we are to be code specific the branch circuit needs to originate at a service equipment enclosure. That aside I think the most important thing to verify is if the existing branch circuit served a cooktop or range and whether or not the cable is sized correctly for the new free standing range.
Old 03-10-2008, 05:39 PM   #27
3 prong range?
No....a cooktop is burners only...although it does generally drop in.
They make a drop in range also. It is about 6" shorter than a slide in and the cabintry runs under it. Kind of common in the 60's and again in the 00's
Old 03-10-2008, 05:40 PM   #28
3 prong range?
Got it.
Old 03-10-2008, 05:45 PM   #29
3 prong range?
None of us?
The existing wiring you have is 240 volt only and you cannot connect the bare equipment ground to the neutral of the receptacle
Old range circuits were 3 wire. 2 hots and a ground.
Hey, at least I tried being nice
Old 03-10-2008, 05:51 PM   #30
3 prong range?
Yes. We generally spend more time arguing the details than it would take to run a new circuit.
Changing 2 Prong To 3 Prong Outlet JAVAMAN Electrical 38 12-02-2012 07:32 AM
Drop In Range Hook-Up mickey45 Electrical 1 04-08-2007 10:29 PM
Range Wiring jasjks Electrical 2 09-01-2006 12:37 PM
Replacing Stove Top with Range the.vicster Electrical 3 02-23-2006 06:12 PM
3 prong 4 prong 240 ranges. K2eoj Electrical 1 11-21-2005 07:39 AM
