3 Prong Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 09:44 PM   #1
3 prong outlets
I'm changing from 2 to 3 prong outlets. there are the two power wires connected to the old outlet and a set of three wires running through the metel box. Black, white, and red. I can't tell if they are attached to the box itself. The main power box has a firm ground in place. Am I safe to connect a wire from the green connector to the metel box and get ground?
Bob
Boboppa is offline   Reply With Quote
Old 07-09-2012, 09:51 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by Boboppa View Post
I'm changing from 2 to 3 prong outlets. Am I safe to connect a wire from the green connector to the metel box and get ground?
Bob
Depends on the wiring method used, if the old BX actually has a bonding strip contained within the jacket, then yes, you can bond the device to the box... if you are unsure of this, just install a GFCI device.
Old 07-10-2012, 09:14 AM   #3
Rewards Points: 160
(Carefully!) check with a multimeter while the circuit is hot, red probe to the black/hot, and black probe to the metal box. If it shows 120v, it's probably grounded.
matt151617 is offline   Reply With Quote
Old 07-10-2012, 09:33 AM   #4
MarginallyQualified
Rewards Points: 2,464
Take a picture of the cables that attach to that "main power box".
(to be clear: the box where the circuit breakers are)
If the cables are anything other than metal... you're totally sunk.
If they are certain kinds of metal you might be lucky.
Maybe (see above)... but not likely.
a set of three wires running through the metal box...Black, white, and red.
We can get back to this later
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
New Home: 2 Prong Outlets & K&T Wiring (Maybe) weekley14 Electrical 4 05-29-2012 07:56 AM
Changing two prong electrical outlets to grounded three prongs Jabar714 Electrical 4 12-21-2010 01:14 AM
Replace 2 prong outlets with 3 prong outlets rpsjn4 Electrical 27 01-17-2010 01:34 PM
1990 Bounder Motorhome 3 prong outlets actally have no ground connected!! Help! Holering Electrical 5 03-30-2009 12:59 PM
