3-Prong Outlet No Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2012, 09:17 PM   #1
Rewards Points: 208
in my 1950's house, i have one 3-prong outlet that has no ground wire. all the other 3-prong outlets in my house have it.
should i be concerned with this one outlet? what are the negatives of not having ground wire?
Scully is offline   Reply With Quote
Old 02-05-2012, 09:27 PM   #2
Julius793's Avatar
Please search this site for similar threads there should be quite a few.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-05-2012, 09:30 PM   #3
Rewards Points: 12,876
Has the wiring been up graded and new wires run to the outlets or did someone just illegally change the outlets from two, to three hole outlets?
Without a ground it is possible to be killed if you were ever to get shocked. Also it could be detrimental to any modern electronics.
One easy way to protect yourself is to just change it out to a GFI. Still would not be grounded but it would not kill you.
Old 02-05-2012, 09:38 PM   #4
Rewards Points: 208
every single outlet has a copper wire to the ground except for this one outlet. the copper wire looks new so it could be an upgrade.
Old 02-05-2012, 09:43 PM   #5
Licensed electrician
Rewards Points: 1,038
This might be as simple as a loose or missing connection upstream from this receptacle.
Old 02-05-2012, 09:56 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Well you could either replace it with an ungrounded outlet or a gfi
Do you plan on ever using a grounded plug in that particular area,generally a grounded plug is only affective when a grounded cord is plugged into it
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Changing 2 Prong To 3 Prong Outlet JAVAMAN Electrical 38 12-02-2012 07:32 AM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
dryer Outlet change 3 prong to 4 prong oldpirate General DIY Discussions 2 08-06-2008 07:18 PM
